Internet Connectivity For 3 months i have tried to connect my dell laptop to the internrt via a PEAk ii WIRELESS lan USB adaptor. All it does is 'aquiring network address' and hangs - what can i do???
  • Anonymous May 25, 2008
    I have the same problem with my WG511 v2 54 Mbps wireless PC card. It tried to get the IP address when installed and hang.
  • TWODOGS2411 May 28, 2008
    all is working fine, except my router is nolonger encrypted. Is this a problem??
    Scholar:
  • 110 Answers
For some reason your laptop isn't resolving DHCP (in real terms, it's either asking for a network address and getting no reply, or getting a reply it can't understand).
There are a couple of ways to go about solving it.
- try turning any security or encryption the wireless router is using off. If you can connect without security, the problem is in the security settings, not the hardware.
- Check for the router setting called "DHCP server enabled". This should be set to ON. Your router manual will tell you where this may be found. If it's not set to ON then the router won't talk to your network card.
- If these things fail, make sure your computer is running DHCP and asking correctly. To do this, go into Control Panel, Computer Management and look in the Services list for DHCP. If this service is disabled, enable it. If it seems okay, click on it and select "Restart the service" Try again when the service has been restarted.
Posted on May 26, 2008
  • Edward Sheldon
    Edward Sheldon May 28, 2008
    It's only a problem insofar as other people can use your connection, but by unencrypting it you can tell there's no hardware problems with either the router or the computer. It's up to you if - given that you've established there are no hardware problems - you'd like to try and turn on security again.
    Another option that works fine without security on is to limit router connections by MAC address, and only give it one address - your own card. Let me know if you'd like detailed instructions on how to do this.
How to use dell vostro as hotspot
Download "Connectifyme". It is a free version with other powerful options in paid version.
But keep in mind. You either need 2 wireless adapter, 1 for internet connectivity and 1 for hotspot.
Or, you connect to the internet via LAN port and wireless adapter for wireless hotspot.
Or, connect to the internet via LAN port to a wireless modem and hotspot with your builtin wireless adapter.
Let me know if you need more info.
May 27, 2014 | Dell Vostro 1014 Laptop Computer
My Dell Inspiron 560 suddenly stopped connecting to internet through cable-modem.
Onboard adaptor hardware failure? Or is it missing Drivers?
Wireless adaptor - did you install drivers for adaptor? Did you check that WiFi on the adaptor is switched on?
On a side note: I've found that USB 2.0 Wireless N adaptors are the best for connectivity, as they have their drivers on the adaptor, are fully plug and play (Vista/7/8 and even some models on XP). I recommend Transcend (brand name).
Nov 28, 2011 | Dell Inspiron 560 (Intel Pentium Dual Core...
Bought a new acer 5750 laptop (i5 2nd Gen, 6GB RAM) which connected intermittently to my router. PC World phone help worked through network adapter enable/disable and then eventually a full default...
I would try:
1. updating driver
2. try connecting via Ethernet, if the issue is only wireless connectivity, try using a USB wireless network adapter, if that works means your lappy has a bad built in network adapter.
3. Are you locating laptop too far from router?
Good luck.
Mar 09, 2017 | Acer Computers & Internet
ACER ASPIRE ONE D150 - Wired LAN connectivity problem.
hello ptwebster,
please give more details on your mode of connection,ie is the Iomega drive connected to another computer on your network?is it a Network Storage Device?
Feb 04, 2010 | Acer Aspire One PC Notebook
My Latitude D610 Dell laptop is not connecting to the internet via my ZyXel broadcom router. In fact, the laptop doesn't even recognize the router or show the router as an option when I click on "Available...
1. Connect your router via LAN.
2. On your internet type in 192.168.1.1
3. Type 1234 on the password screen.
4. Go on the Wireless LAN tab
5. Un-check the option for Hide SSID
Dec 22, 2009 | Dell Latitude D610 Laptop Computer -...
I have an HP Laptop LAN connection will not connect to internet
The wireless modem you are connecting to is protected with a WEP key. You have to get the WEP key or find another wifi hotspot that is not protected.
You can also get a better antenna for your laptop to see if you can pull in another site.
Jul 30, 2009 | Dell Inspiron 1501 Notebook
Cant connect to the internet.
Click on Start and type CMD. Open CMD and type ipconfig. Check out the IP address V4 for the Local area ethernet adapter or wireless area adpater depending on wireless or wired connection. Any ip address other than of the class 169.254.x.x shoud be considered good. If you have an IP address is any other number other than the above you have a good IP address. to test the internet connectivity type PING www.google.com. If the results are Packets sent 4 Recieved 4 Lost 0 then the issue could be due to Internet Explorer bing corrupt or a firewall blocking the internet access. Power off the computer. Power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll get to teh Advanced Windows boot option screen. Select safe mode with networking and see if the internet works in the safe mode. If yes then it could be the firewall. Uninstall you antivirus and check.
Apr 02, 2009 | Dell Studio 1537 Laptop
Not getting connected to the Broadband internet
Right click on the wireless LAN and then click Repair. Do this in the Control Panel - Network Connections. This will force the wireless LAN card to get a new TCP/IP address from your wireless router.
When you get this Limited connectivity message do a repair - this is a common problem - the wireless connection icon is also on your Task Bar, you can right click in it to do a repair.
Mar 24, 2009 | Toshiba Satellite L355D-S7809 Notebook
Connectivity/activesync and network issues
When using wireless lan with PPC, there are some experience shere with you. 1. You must do an "Reset" after the first time of installing wireless driver into your DELL AXIM. Otherwise, the driver would not work. 2. Microsoft Pocket PC 2002 only can allow one source to access the internet. It can't access internet via the USB and wireless at the same time. Thus, it is more batter way to leave your AXIM alone instead of insert on cradle when you try to access internet via wireless lan. 3. Some of the wireless's CE driver are based on StrongArm, 206MHz, not PXA250, 400MHz. It will got problem when the wireless try to initiate the link between base station and PPC. Try the following step: (i) Make sure you have been install the wireless driver. (ii) Remove your wireless from CF slot. (iii) start->setting->power->processor select "PowerSave" mode and apply it. (iv) Plug wireless into CF slot (v) If you can get an dynamic IP or access internet, you can repet step 3, but select "Auto" mode. Hoping these information can solve your problem.
Sep 19, 2005 | Dell Axim X5 Pocket PC
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
