Question about Nikon Cameras
Nikon FG camera......snapped 2 pictures. On my 3rd picture attempt the shutter locked uo. Changed batteries but camera is still locked up.
  • 667 Answers
You need to turn the speed dial to the M90 or 'B' setting to unlock the camera
Posted on May 23, 2008
I have a Nikon Coolpix P500. I have to depress the shutter release button several time to get it to snap a picture. The indicator light shows a fully charged battery.
Did you change (unnoticed perhaps) anything to the settings?
Be aware your camera needs a little time to focus. And when conditions are bad, like little contrast in the subject or bad light conditions, the camera needs more time to focus.
Please try to shoot in automatic mode. Then when you have a subject press the shutter release button half way. Look if you framed correct and then press fully. This way every time the camera should click.
Jan 30, 2014 | Nikon COOLPIX Cameras
Camera wont snap picture
As long as the orange light is on, the camera is not ready to make a picture. The focus area, should become green, to tell you the camera is in focus. Then you can press the shutter release button complete. Check the settings of the camera, and put it in automatic. When you put it in one of the manual modes pipe P M S or A, the camera will not take a picture when there is not enough lift or something else you did not take in account.
If the camera keeps this way, unless you switched to auto, it could be there is something going on. but let me know it auto des not work.
Jan 27, 2014 | Nikon COOLPIX L810
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Jun 29, 2011 | Nikon FG 35mm SLR Camera
I also have the problem of pictures not in focus. I have made a point to lock in first by pushing halfway down before snapping the picture. It's ridiculous that a picture of an inanimate object is not in...
Set the camera on a firm surface or a tripod and take a few test shots...are they better? If so, that means that you are moving when pressing the shutter.
Oct 29, 2009 | Nikon COOLPIX L100 Digital Camera
Not letting take pics or advance film
Check the batteries first. The electromagnetic shutter requires power to function. To free up the shutter and advance lever, rotate the command switch to "M90" (if I recall). That should re-set the shutter and allow you to advance the lever mechanically.
Jul 04, 2009 | Nikon FG 35mm SLR Camera
Nikon D40 problem, often will not take pictures
Chuck,
Sounds like your lens might be set to M rather than M/A. Try that and let me know.
May 13, 2009 | Nikon D40x Digital Camera
Nikon FG shutter
By "stayed up", do you mean that the mirror remained in the up position so that you could not see anything in the viewfinder or do you mean that the shutter actually remained open? I do not remember the exact features on your camera, but in general, this is what I would do.
1) Remove the film from the camera and take a picture. Note if you see anything in the viewfinder. If you see nothing, the mirror is in the up position. Verify this by removing the lens and opening the door on the camera back. Look through the lens hole. If you can see through the rectangular hole at the film plane, the shutter is open. If instead you something is obstructing the hole, the shutter is closed. In any case DO NOT TOUCH THE SHUTTER! The shutter is what is covering the hole.
2) If the mirror is in the up position, check to see if your camera has a feature that allows locking the mirror in the up position. Some cameras have this feature to allow use of lenses with very short focal lengths. If this is the case, simply unlock the mirror.
3) If the shutter is the problem, your shutter speed may be set to "T", which stands for time. In the time exposure mode, you press the shutter release once to open the shutter and a second time to close the shutter. Cameras with a "T" setting also have a "B" setting, which stands for bulb. This is a throwback to the old days when it was common to use air-powered shutter releases rather then cable releases. The bulb was a rubber bulb that you squeezed to force air through a tube and push a pin to activate the shutter. The "B" setting keeps the shutter open as long as you hold the shutter release in, but as soon as you take your finger off the shutter release, the shutter closes. Both of these settings are used to make timed exposures. If you find that the problem was that the shutter was set to "T", set the shutter speed to 1/25th second or so and try again. The following sequence should occur; the mirror will flip up and the viewfinder image will disappear, the shutter will open for the prescribed time and close, the mirror will return to the down position and you will again see through the viewfinder.
If this does not work, you may need to take it in for repair.
Nov 18, 2008 | Nikon FG 35mm SLR Camera
Monitor goes black
It always does that while it's powering up the flash again. If you're saying it doesn't come back after a few more seconds, that is a problem. Or maybe by that time, the power saver kicks in. You can tell if the power light starts blinking. Then you just have to press the shutter button again to turn it back on.
Aug 20, 2007 | Nikon COOLPIX L5 Digital Camera
Error
Your battery may be near-dead. Nikon SLRs disable the shutter, but still let you view pictures, when the battery is low. Solution? Simply charge the battery.
Jul 26, 2007 | Nikon D50 Digital Camera
Cameras Logo
35 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
