Question about Kenwood KVT-617DVD Car DVD Player
Harness wires my harness wires were cut real short and i dont know what color of wire goes where
The12volt.com
Posted on Jun 07, 2008
2000 pontiac grand am gt radio wiring harness cut need to know how to hard wire in
most of these car the plug is simply a plug for convieince you dont need it to hard wire it you simply match up the colors most of them will be the same and then if there are any left over you should be able to do process of elimination hope this helps
Feb 22, 2014 | 2000 Pontiac Grand Am GT
I need to no where each colored wire goes because i cut the ends off the stock wiring harness when i hook up my aftermarket cd player some of my interior lights dont work or my brake lights dont
Not my area of expertise by any means but logical solution would be to get a voltage tester and start testing between the wires and the fuse panel by removing fuses one by one until you know what fuse affects what wire.
Jun 08, 2011 | Car Audio & Video
Im putting n a stereo but i dont no the color code
The stereo side of the wires should be labeled. Check out the12volt.com for a wiring schematic for the truck side. I advise against cutting and splicing wires for a stereo installation though. They make inexpensive harness adapters that will allow you to splice into the stereo harness without cutting into the factory wiring.
May 23, 2010 | 1998 Dodge Ram 1500 4WD
How to hook up the pioneer stereo to wire harness?
Not real clear on question, but you can buy a direct fit wire harness and the wires are color coded so you don't have to cut and splice your wires on your factory harness.The harness hooks to your factory plug and you wire it to your pioneer stereo wires. Harness is about 7.99 up at most stores.
Nov 03, 2009 | Boss RT-6CK Car Component System
While attempting to change stereo on my volvo 940 turbo I cut wire harness now headlights wont come on
ok that problem is where u cut the wires on the rdaio harness u cut is a dimmer wire for your lights on the radio need to figure out which if u have a autozone or advanced parts store they have a radio wire harnes kit has all color code and wire color tells what goes where and what the wire is for
Oct 05, 2009 | 2007 Avanti Convertible
I dont know which color wires are for what!
Dont know if you tried this already but go to a car audio store and ask for an adapter the plugs into your stereo and then it plugs into the factory wiring harness. its easier and cleaner and less stressfull. if you done so write back and Ill see if I can send you a pick or something.
Apr 07, 2009 | 1996 Kia Sportage
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
I need to know what color are for what on my radio wire harness
Not for sure if I can help.Someone forgot the golden rule.NEVER CUT THE WIRING HARNESS.I dont have the wiring scematics in front of me but the older models had RED for power,BLACK for ground,and the wiring going to the spreakers should be an off color running together going to the speakers.Probably has a six speaker system.Hope I helped.
Feb 03, 2009 | 1994 Chevrolet Camaro
97 color scheme for aux hok up
I could go outside and pop my dash apart real quick and tell you.Its real easy to take it off and pull the cd player and radio right out.Is your wiring harness missing or something?Is that why you need to know what it looks like?
Nov 23, 2008 | 1997 Chevrolet K1500
INSTALLING A CLARION MODEL DRX6375 CAR STEREO INTO MY HONDA ACCORD 1995
If you go to your local stereo shop (or even Wal-Mart..) you can get the harness that plugs directly into your cars wiring for about $5-10. It will have the EXACT same wire colors as the harness that came with the Clarion. Just match them up, plug it in and you're good to go!
Nov 09, 2007 | Clarion DRX6375
Kenwood KVT-617DVD Car DVD Player Logo
136 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
