Question about Frigidaire ATF6000ES Front Load Washer
Front Load not spinning
I have a frigidaire LTF2140ES3 and it just quit spinning last night. It was making some noises during a spin and then the next load it didn't spin. I read some other posts, maybe it's the belt? But I don't know where to look for it at. I haven't taken the machine apart yet though either. Would this be a simple fix? Or should I call a repair guy? The machine is about 2 years old. Does anybody have any schematics for it?
  • pearlw Jun 24, 2008
    Same issue, but the belt looks fine, actually everything looks fine, all wires look like where they are supposed to be. Maybe wiring harness but cant find it!
  • 868 Answers
The back of washer has a access panel with screws that you can remove,once removed you can check if tghe belt broke or not.
Posted on May 23, 2008
I have a Frigidaire front load washer that is suddenly making loud banging noise during spin cycle, could it be a belt?
Check for broken/disconnected springs, disconnected/faulty shock absorbers (dampers). For this you have to disconnect the mains power and open up the machine. Spares can be obtained from this very site - Fixya.
Mar 28, 2013 | Frigidaire Washing Machines
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a front loading clothes washer model ltf2140es3 it use to work great, we moved and now it does not spin , whats up ? it was born in 2006
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
In spin cycle the tub had been making loud noise. Then there was a knocking the last time or two. Then it stopped spinning. The tube won't turn at all. Is this the bearing? Does the tub need to be...
Just had the same problem last night; I took off the back and noticed that the 'shock absorber' was broken. http://www.partstore.com/Part/Electrolux/Frigidaire/fwt449gfs1/Electrolux/Frigidaire/134564200/New.aspx
Not sure if the same part is broken on yours.
Oct 23, 2010 | Frigidaire GLTF1670A Front Load Washer
I have a Frigidaire GLTF2070DS Front Load Washer and during the spin cycle, it started making this horrific noise. I started another load of laundry and now it does not spin. What could be the problem?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 07, 2010 | Frigidaire GLTF2070DS Front Load Washer
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
212 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
