Question about HP LaserJet 5000n Printer
URGENT-- engine test problem in HP LaserJet 5000n
Printer only prints horizontal lines, and shows engine test on giving print command. how to fix the problem?
Iam using hp5000n laser printer. It is giving 13.1 &13.3 error messages freequently. (This is paper jaming problem)
Posted on Jun 24, 2008
I am printing documents to my HP LaserJet 5000n Printer and the printer's not responding. I've tried restarting it and it displays that it's processing a job before displays that it's ready.
Either a corrupted driver or possibly a bad network card or parallel port, depending on how you have it connected. Does the printer print test pages from the on printer control panel ok? If yes, try printing a different document from a different program or try the windows test print from the driver. If it prints the windows test print then likely you have either a corrupted program or file. If it will not print the windows test print then I would delete the driver, download the current HP UPD driver and install that.
Sep 24, 2015 | HP LaserJet 5000n Printer
Printing colored lines
Vertical black lines:Check with another cartridge..Check Teflon sleeve.Vertical white lines:Replace cartridge.. replace transfer roller..Clean laser scanner unit( technical skills required) Horizontal Black lines:Replace cartridge..
Jan 31, 2012 | HP LaserJet 5000n Printer
Hello, my problem is that my laserjet printer p1005 doesnt print anything.. whenever i command it from my pc it doesnt do anything.. i tried changing cartridge but still same prob.... please helllppp...
First, print an Engine Test Page.
To print an Engine Test Page, open and close the cartridge door five times while the printer is in ready mode. The printer should print one page with multiple horizontal lines.
If the engine test page printed, is a comunication problem (PC configuration,PC/Printer conection/Driver bad installed)
Jul 18, 2011 | HP LASERJET P1005 Printer
My HP LaserJet 5000N will only print one copy at a time. No matter how many copies I order, I still get only one copy. I'm on a networked PC using Windows XP. Any ideas?
normally you will need to let the printer know that you have preformed any maintenance on it by clearing the error count after such an error occurs and is fixed it is normally listed under general or service options on the printer menu but you may need to look through the users manual
hope this helps
Robb
Oct 27, 2010 | HP LaserJet 5000n Printer
My printer hp leserjet color 5000n is not printing blue
I use a clear silicone tube to carefully prime the carts by sucking a dab of ink out of the tiny print holes before installation. I am careful to have a tight seal at the holes to prevent getting too much ink and possibly getting it in my mouth.
Aug 26, 2010 | HP LaserJet 5000n Printer
HP laserjet 5000N - Paper jam under the cartridge every time try to print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | HP LaserJet 5000n Printer
HP LaserJet 5000n - Paper jam under the cartridge
Check the tray to make sure the paper stops are set right and that the printer is set for the correct size paper. Clean the feed rollers above the paper in the tray and if necessary, replace them.
Laserjet 2600n
firstly give the calabration command from the setting and if the problem will not solve the clean scanner assy and also problem will come the replace scanner assy
Jul 18, 2008 | HP Color LaserJet 2600n Printer
NO RESPONSE, PRINTER DISPLAY BLANK
sounds like you have a bad formatter....there is a way to circumvent the formatter and print whats called an engine test. this is used just to test the mechanics of the machine and leave the brain out of the equation...
Engine Test Button Location HP laserjet printer 5000 series
The engine test verifies that the print engine is functioning correctly.
The Formatter PCA is completely bypassed during an engine test.
This test is very useful for isolating printer problems. The engine test
prints a full page of lines across the entire printable area, and is also
useful for checking and adjusting registration.
laserjet-5000-engine-test.jpg Note Engine test will print from the last input tray used.
If the last input tray is empty or if the last input source was the duplexer,
then the Engine Test will print from Tray 2 (standard 250 CST).
If Tray 2 is empty (and the last input tray is empty or the last input source
was the duplexer), then the Engine Test will not function.
Printing an Engine Test HP laserjet printers 5000 series
To print an engine test, use a non-metallic object (such as a pencil) to
press the engine test button. A single test page with horizontal lines
will be printed. To print multiple test pages, hold down the engine test
button.
If the engine test prints ok then you have a formatter issue...if you have added memory or a network card try taking them out one at a time to see if the problem goes away. Otherwise the formatter will have to be replaced.
Inkworks
Sep 05, 2007 | HP LaserJet 5000 Printer
HP LaserJet 5000n Printer Logo
93 people viewed this question
Seeker5211
Seeker5211
