Question about Bose PMCII 035323 LCD Remote Control
BOSE PMC 2 REMOTE
HELP. THE REMOTE WILL NOT RECEIVE ANY INFORMATION FROM THE LIFESTYLE 48 MEDIA CENTRE. I HAVE TRIED LONGER AERIAL BUT NO JOY. IS THERE ANYWAY OF BOOSTING THE SIGNAL FROM THE MEDIA CENTRE OR RECEIVER IN THE REMOTE TO SOLVE THIS ISSUE?
KIND REGARDS
  • av master May 25, 2008
    would a 40meg booster work?
5 Suggested Answers
  • 16 Answers
SOURCE: my bose pmcii lcd remote control does not receive a signal from a bose lifestyle 48 receiver
Have you tried using the remote antenna supplied with the Bose system? This connects to the "Remote antenna" socket on the rear of the media centre and is made up of 2 parts: a shielded section (black in colour) that runs past any sources of interference - mains or signal cables, other electronics products - and the unshielded antenna (clear plastic covered copper wire) that must be fully extended vertically to act as an aerial. Position this away from sources of interference and as close to the second room as possible (Bose do a longer version, free of charge in some countries....)
The remotes only have a range of up to 20metres - this will drop the more walls it passes through and the thicker the walls. Any interference can affect this - radio transmitting equipment (WiFi, video sender, but especially products transmitting on the same frequency - 27MHz or 40MHz, e.g wirless thermostats or alarm systems....) or products with poorly shielded transformers. Experiment with swtiching off other electical equipment (including lights if they have a transformer - e.g. halogen spot lamps). If you identify a source, can you move it away.....?
Posted on Jan 16, 2008
SOURCE: frequency used by bose pmc-2
for usa-canada 27.145 MHz and europe 40.685 MHz
Posted on Feb 12, 2010
SOURCE: My Bose remote control RC28TI-27
Did you find a solution? I unscrewed the screw under the battery compartment lid near the rear end of the remote. The rattle is a broken radio frequency antenna. A replacement for this ancient remote is $89 plus shipping and handling. Supposedly the Bose systems can also be programmed with some universal remotes without rf antennae.
Posted on Dec 29, 2010
SOURCE: Bose Remote not linking to Samsung HDTV
I got my bose remote to work when I did a system update on the remote. Turn the TV on. Select the TV video input that connects the system. On the control console, press and hold setup until the system information screen displays. line 5 will display the currently installed console software version. on the remote press any button. Line 10 will display the currently installed remote software version. Do a bose system update. On the control console press setup. on the remote control, press the down arrow until update is highlighted and press ok. make sure yes is highlighed and press ok. on the control console plug a clean usb drive into the usb port.when prompted, remove the usb drive and connect it to a computer. open the drive and double click on the download_launcher file, which should bring you to an update page on bose.com. Once complete, put it back in the control console. When the update is complete remove the usb.
Posted on Mar 06, 2011
Can't link my new lifestyle 48 remote control to my lifestyle 38 system?
If the remote does not work as you expect
If your system does not respond when you press a button on the remote, it could be time to
change batteries. For information on the type of batteries to use and how to change them,
refer to "Replacing the remote control batteries" on page 51
In some buildings, you may experience "dead spots" where the remote control will not
operate effectively. If this happens, move the remote a foot or two and try again. Also make
sure the cord that connects the power supply to the media center (and contains the remote
antenna) is stretched to its full length and is separated from other power cords. If these
efforts do not work, move the media center a few feet to a location where it provides a better
response.
If the batteries are fine and the suggestions concerning "dead spots," above do not work,
you may need an antenna extender. To contact Bose
customer service to request one, refer
to the address list included with the system.
Source
Dec 31, 2013 | Audio Players & Recorders
Bose rc48s2 remote not receiving signal
make sure the lens on the remote and the one on the Bose are clean. If that does not work, replace the remote. Buy a used on on ebay.
Dec 21, 2013 | Bose RC-48S Remote
I have a BOSE Lifestyle 48 without sound
Not sure if this is the same problem, but I lost audio from the Stored, TV, Radio and my external speakers, but still had audio for the CD/DVD. I contacted Bose (Australia) support and they talked me through a solution that worked for me.
Remove the power cord from the Media centre, then while holding down the 'All Off' and 'Vol down' buttons on the Media Centre, reconnect the power (and continue to hold the buttons down). After 10 secs, release the buttons and turn the Media centre on. Everything worked fine for me after doing this.
Full marks to Bose for the phone support. I hope this helps someone else.
Jun 24, 2009 | Bose Lifestyle 48 System
Bose link AL8 connection problems
I had a similar problem, though intermittent, using my 48 with the AL8 and room-mate speakers. I kept getting a "no signal received from media centre" message on the remote in the second room.
Assuming that the batteries are ok and you don't have a hardware problem, the problem might be that the 48 is not picking up the signal from your remote control in your second room. The signal from your remote control is a radio signal that goes directly to the 48 - it doesn't communicate via the AL8 receiver. I think the orange light will only turn green once a signal is being transmitted from the transmitter unit plugged into your 48 media centre, and this won't start transmitting until the media centre gets a signal from the remote telling it to switch on.
The aerial for all the remote controls is contained in the power cable that links the 48 lifestyle unit to your VS-2 unit. Make sure that this is uncoiled and oriented vertically, as far away from other cables as possible.
If this doesn't work, you can get an antenna extender that plugs into the RC socket on the back of the lifestyle system. Again, orient this vertically. You can get these from Bose.
Is there anything in the wall that might be blocking the radio signal? Lots of metalwork for example?
If orienting the power cable from the VS-2 doesn't do the trick, I suggest that you go to a local Bose shop. (An actual Bose shop, not just an electrical or hifi store stocking Bose products). I explained my problem and the tech guy gave me an extender gratis (its basically just an FM aerial wire by the look of it). I installed it this morning and, so far, its seems to be working ok. As my unit is fairly new, he also offered to have the kit back in the shop to check it all out and, if that didn't work gave me Bose technical support number. He even offered, if all else failed, to send a guy out to my home to get it working - and I didn't even buy it from there!
Hope this helps.
Jan 04, 2009 | Bose link AL8 wireless home-wide audio...
Lifestyle 48 Acoustic module doesn't work
Call Bose tech support. They fix or replace these under warranty. I have a lifestyle 12, original model, after two repairs in. Ore than 10 years, I was allowed to upgrade to top of the line for the price difference.
Mar 16, 2017 | Bose Lifestyle 48 System
Frozen bose lifestyle 48 IV
turn off the accoustimas, unplug the power code from the accoustimas and the media center and leave it for 15 sec. Then, plug the power code onto the accoustimas and turn it on. then plug the power code of the media center on. Turn media center on.
hope this helps
Apr 15, 2008 | Bose Lifestyle 48 System
Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Jan 26, 2008 | Bose Lifestyle 48 System
Bose Lifestyle 48 Series IV
hate to stae the obvious and painfull answer, but that nees to go back to the shop where if the sales guy cant get it sorted for you it could be a firmware crash and tus a warranty replacement, i know the manual is not that good in this specif area. and a non warranty reset may cost money, if warranty does not cover this specific area of adventure as it is possible they could blame the content of the media being corrupted in some way, could be ahrd one.
however you could try remoing the disk and resetting the system according to manual frist.
good luck ;-)
Dec 09, 2007 | BOSE48 - Lifestyle 48 Home Entertainment...
My bose pmcii lcd remote control does not receive a signal from a bose lifestyle 48 receiver. I made all the connections for the wireless system whose receiver is getting a stron signal from the...
Oct 21, 2007 | Bose PMCII 035323 LCD Remote Control
Bose PMCII 035323 LCD Remote Control Logo
412 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
