Question about SanDisk Sansa c240 MP3 Player
Screen The screen is gray. It does not display anything. It plays and charges but I have to keep pressing buttons to listen to the radio or play recorded songs. I've had it for about 8 months. Do I need a new battery? barbara
  • 8,596 Answers
Reset the player, and then run the Sansa Recovery Tool, Here are a few other "Soft" methods: (but, keep in mind, your player may be experiencing a hardware issue with the LCD screen - if none of the below methods work, the player will need to be replaced - non-replaceable battery:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 23, 2008
How do i play back a recording i've made? I have the Sansa m200 series MP3 Player
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: http://kb.sandisk.com/app/answers/detail/a_id/241 . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Mar 25, 2014 | SanDisk Sansa m240 MP3 Player
When the radio is on, the clock will not display. When the radio is off the time is displayed. How do you set the time and get it to display when the radio is on.
To set time:
Press the [D] button for one second or longer to switch to the adjustment selection display. Press the > button to select "Clock". Press the play button. Press > to select between hours and minutes. Use the rotary knob to set the time. Press play to complete. then press [D] to return to the previous menu. To display the time, you should just have to press the [D] button while playing a CD or listening to the radio.
Feb 24, 2011 | Clarion DB245 CD Player
No display
Try resetting it by using a sharp object, like a pin and press the reset button with pin ect.
Jul 08, 2009 | Samsung Yepp YP-P2 Digital Media Player
Gray Stripes displayed when playing video
I am having the same problem with a Sony Digital 8, When I hit play I see blue screen buy when I press play and fast foward I see the same gray scan lines> Did you have a stuck tape or problems ejecting tape? I think it is more than cleaning the heads. When I try to record it indicates no tape in camera.
Apr 25, 2009 | Canon DC210 DVD Camcorder
No Manual (instructions) for Jazz hdv178
Press RECORD/PLAY Button to switch from Record Mode to Playback Mode.
The Playback Mode is for viewing and managing movies and pictures as well as listening to voice and
music on the built-in memory or on an optional memory card.
Operation Display Screen
Press RECORD/PLAY Button ( ) to switch
from Record Mode to Playback Mode Main Menu.
• There are 4 options in the Playback Mode, movie,
picture, music and voice.
• Direction Buttons can be used to select the
specific option.
• Press OK Button to view movies/pictures, listen to
voice or music.
Feb 18, 2009 | Jazz DV-179 Digital Camera
Downloading instructions Delphi SKYFi3 unit
You can't download Xm programming, like you can from itunes, where you get a song in 3 or 4 seconds.
Do you mean record music? You must record realtime, either while listening or while the unit is idle in its cradle.
It's easy. while listening to the radio in the cradle (press mode repeatedly to get to Live XM mode), then press the center (play/pause) button.  the menu will pop-up, select Record.  It will give you the option for Song, Channel, and Session.  Just chose one of the first two and press the button.  You should see a microphone appear at the top of the screen.  It's recording.  Follow the same steps to stop the recording.  Setting up a recording session is self-explanatory once you get into that screen.
Oct 21, 2008 | Delphi SKYFi3 XM Radio Receiver
Recording from camcorder problems
does the unit display what it's pointed at on its display screen or on the viewfinder? if the unit will play a disk but not record the problem may be in the lense or the video sensor. Check if the autofocus operates by running your hand across the front of the unit. if the autofocus knob or lever doesn't turn it may be the power. otherwise it may not operate with -R but only with +R disks?
Nov 14, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
Display of recorded programs does not match the program playing
There is a very small reset button under the back cover. You will need a small paper clip to reach the button. It is located in the upper left hand corner. The button is not under the batt., it is about 2" above the screw on the side. I don't know if this will solve your problem, but it should reset your radio to its default settings. Good Luck!
Apr 29, 2007 | Tao XM2go Satellite Radio Receiver
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
Note:
You must have at least one photo saved to record a sound memo.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
SanDisk Sansa c240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
