Question about HP LaserJet 1300 Printer
When i print all appears on one page
When i print , all appears on one paper and can not read
Try this if you still have the problem. I ran into the same problem on our HP1300n. Once I changed the processor the problem went away. Hope this helps.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1193993
Posted on Jul 24, 2008
How do I take a meter reading on my HP-M603DN Hewlett Packard Mono M603DN printer?
You need to print the configuration page. Scroll through the menus on the printer until you find administration, then select reports and then configuration page. The engine cycles will appear in the upper left hand side of the first page that prints.
Sep 22, 2014 | HP LaserJet 600 M603DN Laser Printer -...
Tip
How to get the page count on a Brother HL-6050
To obtain a page count (also called a meter reading) from a Brother HL-6050 printer, follow the steps below. (This procedure also applies to the HL-6050D and the HL-6050DN models.)
A. When the machine is on and ready to print, press any of the following keys to bring up the menu: Set, Back, +, or -.
B. The first menu heading that appears is Information; press Set to select it.
C. Use the + or - keys to scroll through the Information menu until you see Maintenance.
D. Press Set to select it.
E. The first option that you'll see is Page Counter; press Set to view the count.
The number of pages printed so far will appear on the screen. Once you've seen or recorded this number, keep pressing the Back button until you're back at the Ready screen.
If you would rather have a printout with the page count on it, you can get that instead by simply pressing the Set button three times from the Ready screen. The first time you press it you'll bring up the menus, the second time you'll select the Information menu, and the third time you'll select Print Settings. When you choose Print Settings, three pages of information will print out, showing supply usage, jam counters, and machine settings. On the second page, about halfway down the page under the <Device Status> heading, you'll see the page count. Beneath the page count, you can also find the number of pages printed from each paper tray, as well as the page count broken down by paper size (for example, letter-size paper, legal-size paper, or envelopes).
on Sep 16, 2010 | Brother HL 6050 Laser Printer
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
HP 2840 unexpexted paper size
You must properly configure your paper size from the menu.
If you can not configure it with the default sizes, try to do it manually by adjusting thedimensions of the paper.
Apr 30, 2012 | HP LaserJet Office Equipment & Supplies
When printing on the 4250, the margins are moved to the right of the paper cutting off the text. This is an XP computer and the PCL and PS drivers have been tested...
I would check to make sure that the paper trays are set properly and paper size is being detected properly. Print out the configuration page and see if that prints correctly. If it shows the same shift in image, check the paper sizes that the configuration sheet shows to make sure it is reading the trays properly. If the trays are reading properly and test print prints properly, then it is either your driver or the software you are printing from that has a problem.
To print the configuration sheet, press the down arrow button until the screen reads "information", press checkmark and then use the down arrow until "configuration page" is highlighted and then press the checkmark again. After a few seconds your page will print.
Apr 27, 2011 | Office Equipment & Supplies
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
I have a canon pixma ip4200. When printing it draws the paper in but then stops. The heads print as if the paper were there but the printer doesn't draw the paper through. please help...!
Use Fit-to-Page Printing (Windows) The Fit-to-Page function automatically resizes the image to fit the size of the page being used. Letter size image data, for example, will automatically be printed on 4" x 6" size paper. Paper sizes larger than the printer can handle will be available on the Page Setup of the printer driver but will not print unless the Fit-to-Page function is enabled. Note: The Fit-to-Page Printing function is not available when Borderless Printing is selected.
  1. Access the printing preferences by opening the printer Properties / Preferences:
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click the Page Setup tab.
  3. Specify the 'Fit-to-Page Printing' settings.
(1) Select Fit-to-Page Printing.
(2) Select the size of original document created in application program. Paper sizes larger than the printer can handle will be available.
(3) Select the actual size of print media.
Click 'OK'.
I hope it helps!!!
Dec 02, 2008 | Office Equipment & Supplies
Canon MP6oo paper tray empty
Issue: "The selected paper size is not supported by your printer..." appears after selecting the Paper Size in the printer driver.
Solution: Use Fit-to-Page Printing (Windows)
    For Windows Vista
  4. Click 'OK'.
May 15, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
HP LaserJet 1300 Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
