Only one speaker working on dvd player portable
  • 31 Answers
That may be due to bad assembly, misshandling or bad components, if under warranty you should return it and have the player checked out. If a headset is plugged in and both sides work then the problem is probably the Speaker or the wiring from the headphone socket to the speaker. If there is a balance control, check it is set at the balance point first. The headset will give a balanced signal if it is...
Posted on May 23, 2008
Just need advice regarding connection to a speaker system, ( altec-lansing ADA885).
a portable DVD player usually doesn't have speaker or line outputs, if yours does just those (red and white) and connect to audio in of the altec lasnings. if no audio output connectors, use the earphone jack with an adaper (1/8 stereo male to stereo pair rca male.
Mar 17, 2011 | Zenith DVP615 Portable DVD Player
No sound out of dvd player speakers but headsets work
it could be that the jack where you conect the Headset is locked on headset when you unplug the headset it should go to speakers.
ecrdn@yahoo.com
Jack
Oct 20, 2010 | Dynex DX-PDVD7 Portable DVD Player
Shinco Portable DVD SDP-1731A - Sound not working.
I have had a couple of these with the same problem , and in 2 out of the three cases the cure was the same .. Earphone socket fault ?
Ear phone sockets are designed to dissconect the speakers on insertion but with the constant use and pulling they get on a mobile system they sometimes lock open and do not reconnect the speakers you could check that ..
The other one I had was diffrent that one the sound output chip was faulty and had to be replaced as did the speaker output capacitors , one had failed causing the chip to overheat .. hope this helps Regards Vortash
May 12, 2009 | Shinco SDP-1730 Portable DVD Player
Audio on portable DVD player decreasing.
Could be a blown speaker or the amp circuitry driving the speaker is bad. One way you can get around this is to run the audio through the auxillary output of your dvd through either headphones, your car stereo through a line input, or hook up a pair of external speakers to the player.
A lot of times the quality of the audio in the built in speaker on portable DVD players is not of good quality to begin with. The above suggestions should correct it.
Dec 10, 2008 | Audiovox D1708 Portable DVD Player
Audio trouble
Is the mute button on the dvd player on? Have you tried turning up the volume on the DVD player, have the speakers been working before? Have you always got headphones plugged in? Have you checked the audio setting on the DVD player?
Nov 01, 2008 | Televison & Video
Sound issue
Check your settings in the menu of the dvd player you can do this with or without a dvd in it. If not a setting it maybe the speaker/s are blown try putting earphones in if you get sound from them it is probably the speakers.
Jul 23, 2008 | Mintek MDP-1815 Portable DVD Player
Portable DVD player
One simple way to check if it's the player acting up or if it's in a different mode is to switch the SOURCE toggle on the left side of the player (above the headphone jacks). If the switch is flipped, the player is set to be a monitor for a different source device (i.e. connecting a VCR or DVD player to the portable player to use the screen and speakers).
If this doesn't work, then you should take the player back to Best Buy to be looked at by a technician.
Jun 09, 2008 | Insignia IS-PDVD10 Portable DVD Player
Poor sound quality/Speakers not working
That might be because :
-Your using a burned DVD
-It's just a piece of shit
-You need new headphones
Dec 27, 2007 | Durabrand 8.5'' Portable DVD Player
Durabrand portable dvd player
Try pressing the l/r button which adjusts the Left and right speakers and will fix the problem...
Aug 15, 2007 | Durabrand DUR-1700 Portable DVD Player
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
