Question about Whirlpool Washing Machines
Heavy duty Series 8 Commercial Top loading washing machine
Intermiitent problem whereby machine will sometimes not spin. This is irrespective of the size of load. I have years of technical experience and am an electrician. With a PA34 4XA postcode you will see why getting one of your engineers in maybe a problem. Is there any particular fault that can cause such an intermittent fault? It only occurs about one in 10 washes.
All wiring terminals have been checked and visual inspection of wiring loom.
  • Kedhle May 23, 2008
    You're spot on. The machine sits on an unstable floor in a shed so the problem will be compounded. Many thanks from the North West coast of Scotland
  • 868 Answers
The connection to focus on are your un balanced sensors.If you can ,replace them,make extra sure your harness contacts are all touching.My belief is the design of this machine is filled with so many mistakes.Its to bad that we are gambling every time we make a purchase ,what ever happened to quality control.
Posted on May 23, 2008
I have a frigidaire washing machine and it spins out just a small amout of water during the cycle, not a lot , have checked the pump and it works, just wondering if it could possibly be the lid lock
It would not agitate if it were the lid lock, just as agitation should stop when you open the lid during cycles. More likely it's something blocking the drain hose. Here is a link to an excellent online repair manual. Click on the picture of the wash machine, then go to chapter 2. Then have a look at Section 2-3.
http://appliancerepair.net/washing-machine-repair-2.html
Sep 13, 2012 | Frigidaire Washing Machines
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
Have kenmore heavy duty 80 series about 15 years old. It will not go into spinning mode after washing mode or rinse mode as it is supposed to.. By fooling with the controls I can eventually get it to...
heatman101
Aug 27, 2010 | Kenmore Washing Machines
How remove wash machine top
On these machines there are no screws holding the top down, get under it and pop it up using a tool that won't scratch the finish.
First I would try removing the front panel to see if it could be done through the front. Its only held by two screws in the bottom.
Good Luck
Quentin
Sep 29, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Instruction manual for Whirlpool Heavy Duty Series 8 Machine
I have the manual if you need help, but the mechine is simple to use, just put the fabric conditioner in the top of the thing in the middle (inside the machine) the bleach dispenser is is just for bleach. You just get a cup of washing poweder and throw it in!
Mar 21, 2009 | Washing Machines
Kenmore heavy duty series washer
you need a new timer. order part thru sears.
Mar 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 8 series Top Load Washer Heavy Duty
betwen the motor and the transmission there is a drive coupling made of plastic and rubber in between the 2 plastic drives that is your problem replace the drive coupler and let me know how you make out
Sep 11, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
106 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
