How to uninstall Vista and load XP in Lenovo Y510 Ideapad
I have purchased one Lenovo Laptop (Ideapad 510) with preloaded Vista. I want to remove Vista and install XP. Whenever I try to do so with the bootdisk of XP, a blue screen pops up with some error message relating to file "pci.sys". Can you please help me by telling how to install XP?
  • 4 more comments
  • pspatil10 Jun 26, 2008
    h have purchased a lenova laptop (2330) with preloaded operating system windows vista. now i found that mostly software which i need are not installing on my laptop because of vista. so i need to change my OS to windows XP. how can i do it as i am not a software realated person. should i call to system techncian? or can i do it himself ? and how?
  • minu143mitu Aug 21, 2008
  • Anonymous Sep 09, 2008
    when i install windows xp sp2 then a message hdd is no found seen how can i install windows xp sp2 in Y-510 series lenovo notebook.
  • indpsreddy Nov 03, 2008
    I have purchased one Lenovo Laptop (Ideapad 510) with preloaded Vista. I want to remove Vista and install XP. Whenever I try to do so with the product key that not supporting.please solve my problem
  • Anonymous Mar 28, 2014
    I was trying to make itunes play songs, and installed the conexant audio drive which seemed to solve the problem for others who had the same issue. restarted, and now there's no audio at all from youtube, 8tracks, or itunes.
  • Anonymous Apr 01, 2014
    I think I hit a sequence of keys and it made my Lenovo IdeaPad P500 LCD screen display very dim
    President:
  • 2,712 Answers
Several points:
1. Although you may prefer XP to Vista, it is probable that you are simply
more familiar with it. If you would give yourself some time to become
accustomed to Vista, you might find that you like it. I know I do.
2. You can't literally "uninstall" Vista, but if you want XP instead, you
simply do a clean installation of XP the normal way. That will format the
drive, removing whatever is on it.
3. Do you already have a copy of XP you want to install? Did it come with
your old computer? If so you need to be aware that OEM versions (such as
those that came preinstalled on computers) are permanently tied by their
license to the first computer they are installed on. If that's your
situation, your copy of XP is not available to be used on your new laptop.
4. Over and above the licensing issue in point 3, many OEM version of
Windows XP are BIOS-locked to the computer they came with, and you actually
won't be able to install it on a different one.
5. You should check with your vendor to be sure, but the warranty on your
new computer may be voided if you change operating systems.
6. Laptops often have special drivers they need for components within them.
Your new laptop undoubtedly came with all the drivers needed for Vista, but
it didn't come with the drivers needed for Windows XP. Finding and getting
the drivers you need may be a problem.
If I were in your shoes, I'd stick with Vista.
If you still want to uninstall:
The normal way to "uninstall" any operating system is to format
the hard drive and install a new OS of your choice.
After backing up any data you wish to transfer to the new OS
installation, simply boot from the WinXP Home installation CD. You'll
be offered the opportunity to delete, create, and format partitions as
part of the installation process. (You may need to re-arrange the order
of boot devices in the PC's BIOS to boot from the CD.)
HOW TO Install Windows XP
http://support.microsoft.com/default...B;en-us;316941
http://www.michaelstevenstech.com/cleanxpinstall.html
http://www.webtree.ca/windowsxp/clean_install.htm
Then the backed up data can be restored and applications re-installed.
You can even try a dual boot, where you have both Vista and XP on the same system. Click HERE for pictorial guide.
Posted on May 25, 2008
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
I had the same problem..I have a Lenovo S10-2 and when i tried to install xp instead of win 7, i got that blue screen too..But after i changed SATA setting from BIOS, i could install it with my usb disk..
Posted on Mar 03, 2010
I really gave vista a try, i wanted to so bad. It just gave me endless compatibility problems with even "vista certified products" needless to say i had to wipe it out and get xp. aside from small keyboard problems (does anyone know how to get the brightness buttons working?) xp runs smoothly for me. Great laptop for the price!! They should give you an OS option when ordering.
Posted on Sep 11, 2008
XP can be installed easily on the Lenovo Ideapad. Lenovo has directions. follow directions to change the BIOS setting for the SATA drive to compatable (see lenovo or just press F2 when booting and lenovo in on screen).
Only prob I found was that the keyboard behaves poorly and erratically with XP- still working on that one.
Lenovo is too authoratarian and will NOT extend warranty help to anyone who has changed to XP.( "change it back to Vista and call back" they say...so don't tell them)
Posted on Aug 26, 2008
    Genius:
  • 3,422 Answers
You can have a look HERE what microsoft says about this error.
You''l need Windows XP SP2 to support a PCI-Express graphics card.
If you are using only PCI-Express graphics card, the only choice is to boot from the complete edition of Windows XP SP2.
If you intend to install with Windows XP or Windows XP SP1 and then use the upgrade kit of SP2, please disable PCI-Express in BIOS before starting the installation.
Under this circumstance, only PCI graphics card can help you monitoring the installation process at this stage. Then, upgrade the version to SP2. After upgrading is successfully completed, you can enable PCI-Express and start using PCI-Express graphics card.
Goodluck.
Posted on May 23, 2008
My lenovo ideapad Y510 is not able to start windows vista which was preloaded into it when purchased.as soon as it is switched on, fan start running and it gets shut down after sometime without starting...
This sounds like a problem with the operating system. The best way I know to fix this is to wipe the old operating system off and install windows 7 with a full install disc.
Windows 7 Home Premium is more stable and faster than Vista ever was, but will cost $199.99 or so for the full version, or if it's possible to install with the upgrade, $119.99 or so from Microsoft.com.
If your Vista could be started, you could theoretically go to the recovery console and 'recover' it or go to help-> restore and restore to an earlier date where the computer wasn't malfunctioning. However, these options aren't available if you cannot even start windows.
Feb 02, 2011 | Lenovo IdeaPad Y510 Notebook
WEB CAM IS NOT WORKING IN MY LENOVO IDEAPAD Y510 LAPTOP AFTER INSTALLIN WINDOWS 7. PLEASE GUIDE ME.
Hi satyadevbujj,
Based on concern, Y510 camera driver for Windows 7 is not yet released based on Lenovo's support download site. Hence, you still can try updating the camera using the windows vista camera driver. Just go to this link.
--> after downloading, install the driver then restart your computer.
Hope it helps,
Thank you for using FixYa.
Oct 21, 2010 | Lenovo IdeaPad Y510 Notebook
Can't find drivers for win 7 64-bit for lenovo y510
Windows 7 is a new platform and every hardware manufacture is developing the driver suits for it.Meanwhile you will have to download the drivers directly from the chip manufacturers site e.g. for sound you can download it from http://www.realtek.com.tw/downloads/.
About the chip manufacturers you can know from the Y510 page where the drivers are there for Vista or XP.
Thanks.
Dec 28, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
Lenovo touch pad not working properly
Please update the Touchpad driver from www.lenovo.com
May 25, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
I want to install XP in lenovo y510
okie! a question? i have installed windows Xp with Sp3 on my Y510. Now whenever I try switching back to AHCI mode i end up with a BSOD. would it make any difference if i leave it in the compatibility mode? or how can i get it back to AHCI mode
Feb 17, 2009 | Lenovo IdeaPad Y510 Notebook
I want help sir please help i have lenovo y 510 mmc card reader is not working windose xp in my system
u can find the drivers here - http://www.opendrivers.com/freedownload/287617/lenovo-ideapad-y510-card-reader-driver-windows-vista-32bit-download.html
Dec 26, 2008 | Lenovo IdeaPad Y510 Notebook
Lenovo driver problem
Check the following location for the drivers for your Ideapad Y510.
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=12
The drivers for lenovo y410 will not work for your laptop.
In fact most of the XP drivers at the above link were available since December 2007
Hope this helps.
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
2,759 people viewed this question
David Payne
David Payne
