My samsung ht-thx 22 dvd player turns off after a few minuits it reads PROTECTION when it switches off
  • Anonymous Jul 10, 2008
    This also happens with my Samsung HT P1200 Home theather system. It shuts itself down, while there says Protection on the display
  • Reinmar May 11, 2009
    The same as earlier mentioned. It is very irritating.
SOURCE: I Need the Dvd
I Need the Dvd region codes for my Samsung HT-TX35 DVd Player
Posted on May 30, 2008
SOURCE: Samsung HT-DB600
i think you hold down the stop button on the player for like 8 seconds or something while the player is off. that is suppossed to reset it.
Posted on Jun 13, 2007
SOURCE: SAMSUNG DVD MODEL HT DS610B
try installing drivers from the dvd and check if you have installed motherboard drivers properly
Posted on Jan 30, 2008
drlalitv
  • 488 Answers
SOURCE: I have a samsung DVD
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Posted on Nov 18, 2008
SOURCE: samsung dvd home theater HT d5610
I am looking for and to purchase an antenna for my HT D5610. Thank you for any help you can provide me with.
Posted on Feb 01, 2009
I have a samsung ht -tx 22 dvd home cinema system and for sometime now, the screen shows PROTECTION and it reverts to standby mode by itself.. Need help badly as sometimes it plays for 1 to 5 minutes and...
Check all your cables, connections and speakers. If they are all good, then either there is a fault on the protection circuit or the power amp has a fault on it. If the unit has a fan built into it check that is working. Sometimes the fan can get blocked up.
Sep 24, 2017 | Audio Players & Recorders
My Samsung HT-TX72 doesn't read the DVD's
Sounds like to optical pickup (laser) has gone bad. Unfortunately on this model Samsung never made just the pickup available for replacement, they always made you replace the entire changer. The last few times I've tried to find this part for replacement I haven't been able to locate one.
Mar 17, 2013 | Televison & Video
Dvd player wont play burned movies
most of the movie if download from the net protected my different formating keeping people from burning and selling coppies. as long as your dvd play dvd is working fine. I got lots of those downloaded movies from a friend myself some play and some dont. I bet you if you go through most of your copy dvd some will play and some dont. Your sysytem may read some dvd VS mine may read some of your's that you system dont reads, you will not find a unit" DVD" will deformat the protection copy rights. I have 850.00 unit almost top of the line still wont read lots of copy DVD.
Jun 04, 2009 | Samsung HT-DB600 System
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Dvd home theather system
The audio amplifier IC are fried and need to be replaced
Mar 31, 2009 | Samsung HT-X40 System
"Protect" error - HTZ110
Home Theater System Is Displaying "Protection" spacer.gif As soon as the unit is turned on, the word "PROTECTION" will flash on the front panel of the unit and SHUT OFF. This error message usually indicates that the fan in the back of the unit is not on.
The PROTECTION feature automatically shuts down the unit to avoid further damage. The unit will need service if this error message is displayed.
Please use our ASC Locator to find your nearest Authorized Service Center
from samsung's web
http://www.samsung.com/au/support/faqs/supportFaqList.do?group=&type=hometheatre&subtype=hometheatresystems&model_nm=HT-Z110&dType=D&mType=UM&vType=R&prd_ia_cd=03030100&acc_ia_fl=&disp_nm=HT-Z110&menu=faqs
Jan 18, 2009 | Audio Players & Recorders
My Samsung HT-40 home theater system throws itself into protection mode and shuts down. I put a new fan motor in but it insists on shutting down anywhere from 10 to 60 minutes of operation. No dust...
The fan is going bad and if you have replaced it try to open the case and remove the cover over all the capaciters and what not and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever! make sure u turn on the recever for 10 min if the fan is not turning by then its still not good
Dec 18, 2008 | Samsung Televison & Video
Samsung dvd home theater HT d5610
This sounds like a short circut (check speaker and other conections to make sure none are touching each other or a metal contact!
That should fix ya!
Dec 18, 2008 | Samsung DVD-R155
PROTECTION
See my post "HT-DB120 - PROTECTION due to shorted output stage "
Jan 02, 2007 | Samsung HT-DB120 System
Televison & Video Logo
674 people viewed this question
Top Televison & Video Experts
Electro Med Services...
