Question about Intel Motherboard
Mercury Mainboard PVCLE266M-L v3 Manual
Hi need help desperately,
My power supply failed and I have put mainboard in new case with new powersupply but cannot find manual with diagram for the front usb wiring and power on switch wiring etc.
I have been to Mercury's website with no luck at downloading manual if anyone has the manual for download could they please emial me .
Many thanks in advance,
narrogin6312@yahoo.com.au
i HAVE ONE P3 DESKTOP COMPUTER.bACK SIDE OF PROCESSOR ETHERNET CABLE PORT (INBUILT WITH MOTHERBOARD)IS AVAILABLE.i CONNECTED INTERNET CABLE(ETHERNET CABLE)NET CONNECTION IS NOT DETECTING. I DON'T KNOW ACTUALLY WHAT IS THE PROBLEM?. MY MOTHERBOARD IS MERCURY PCVLE266M-L V3.0A.
i CHECKED IN DEVICE MANAGER BUT I COULDN'T ABLE TO SEE NETWORK ADAPTERS.
WHAT I CAN DO?
IF ANY LAN DRIVER DOWNLOADING IS REQUIRED , FROM WHERE i CAN DOWNLOAD THIS DRIVER?
SO PLS GIVE ME A ANSWER FOR THIS PROBLEM AS EARLY AS POSSIABLE.
  • shahkrunalp Jun 28, 2008
    Please describe the specifics of your problem below. We'll add
    your post as a comment to MERCURY's Mercury Mainboard PVCLE266M-L v3 Manual problem, and notify you when a new solution is offered.
    Genius:
  • 1,027 Answers
Go to Mercury's website, and under 'download drivers' is all the information you need. The drivers for the various devices are there, and a downloadable copy of the manual.
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=439
The USB cable to the fron panel and the mother board look similar. The cable and board will have 1 pin missing at the end of the connector, and that is the orientation to connect it.
You need the network drivers to activate the network connection (also at mercury's website)
Posted on May 23, 2008
I have a problem in my pc when i switch on its bring the sound only without showing anything what should i do?
Posted on Aug 11, 2008
Can i put gaming power supply to my msi rc410m-l?
Hello here is the mainboards homepage:
http://www.msi.com/product/mb/RC410M-F--L--FI--LA.html#/?div=Detail
Any ATX power supply will fit your mainboard.
I will recommend to buy a power supply of a good brand like corsair, because the cheap one does not last long.
I would choose one not under 500 watts.
If you change the powersupply yourself, please take antistatic precautions when working on the mainboard.
Pricerange is 100 to 200 dollars depending on how big it has to be.
Remember also to arrange cables so its not blocking vents and fans.
Good luck
Sep 17, 2013 | Computers & Internet
Motherboard diagram
Hello i can help you with the manual:
http://www.gigabyte.com/products/product-page.aspx?pid=1792#manual
There are no fuses on the mainboard, not even in the powersupply.
The power supply maybe contains a thermal switch, but it does not pay to let it be changed.
The solution is to buy a new or used power supply.
If still no life when the power supply is changed, the mainboard is dead.
Good luck
Jun 25, 2013 | Gigabyte Giga-Byte: 8S651MP-RZ...
M26gtm power supply
Helloo here is the homepage:
http://www.jetway.com.tw/jw/motherboard_view.asp?productid=223&proname=M26GTM-3VP
Any ATX power supply can be used here, the main connections is 24 pin, and all power supply will fit the mainboard.
Try to download the manual, for detailed info about how to connect the power supply.
Please take antistatic precautions, when working on the mainboard.
A computer repair shop, can also help you with renewing the powersupply.
Good luck
Jan 24, 2013 | Jetway 1GB M26GTM-3VP 800MHz UDIMM
Hey All, THIS IS URGENT. My PVCLE266M-L V3.0a will not boot into any OS. I have 2 identical boards. I can navigate BIOS on both of them with the DDR400 512MB RAM stick I have put in. (The specifications...
Your mainboard PVCLE266M-L does not support the DDR 400 Mhz RAM (PC3200) ie @ 400Mhz frequency. For the memory specfications it support "2 x 184-pin DIMM sockets support two2.5V DDR SDRAMs (DDR266)" maximium is 2GB or DDR PC2100 ie @ 266Mhz frequency.
PC133 is the SDRAM so it will not fit the DDR RAM slot.
You should not use the 400MhzDDR memory RAM on a Mainboard with a FSB(Front Side Bus) of 133 Mhz and the 400Mhz DDR Ram is not compatible with the mainboard.
Get the DDR 266 with double side chipset i.e.DDR1 RAM (DDR PC2100) RAM and it will be compatible with your mainboard. Sometimes single side chipset DDR1 RAM will not work on older mainboard.
Hope it helps.
Jul 10, 2011 | Mercury Computers & Internet
Plz send driver for sound and vga
plz give me the sound & vga driver
Mar 28, 2009 | Mercury PVCLE266 Motherboard
Error in installing display adapter
Here's a link to the mainboard drivers:
http://www.mercury-pc.com/downloads_list.php?productid=563
Mar 13, 2009 | Enterasys Computers & Internet
I have printer ml-2551n whent I turn on no display work ?and no connectivity
Replace all electrolytic capacitors in power supply section on mainboard. caused by poor quality lower voltage lower temp caps being used in powersupply and being put right beside a heatsink (Der are we clever or what) . Problem will reoccur every 2 to 3 years if 105oC caps are not used. If mainboard is replaced with new mainboard problem will reoccur within same timeframe. Fix old mainboard using higher voltage and higher temp caps and problem will be gone for good.
Dec 29, 2008 | Samsung ML-2551N Laser Printer
Intel Motherboard Logo
1,622 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
