Question about Hitachi CP-S225 Multimedia Projector
How to reset the lamp timer in Hitachi CP-S225 Projector
A message is being automatically displayed on the projector prompting us to reset the lamp timer. Can you please detail the procedure for the same.
  • jjay999 Dec 22, 2008
    I have the same problem - manual I downloaded states there is a menu option but my system does not have it - any thoughts?
  • hilsbills Apr 20, 2009
    I have replaced the bulb in my projector, but I cannot reset the lamp timer as it will not turn on!
tinamarie49
  • 34 Answers
SOURCE: Hitachi CP-X250 LCD Projector
If both lights are flashing orange, that means that the bulb needs to be replaced and the filter needs to be cleaned. Make sure you reset the counters for both after you replace them.
Posted on Dec 05, 2007
Marrie
  • 563 Answers
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Posted on Mar 26, 2008
Marrie
  • 563 Answers
SOURCE: Hello Wardens wife
Hi Airbala
This Projector does have a filter timer.
Go to the Options Menu and select Filter Time - then reset it.
  • 105 Answers
SOURCE: Resetting the air filter timer
Hitachi CP- RX60:
Press the RESET button on the remote control or the right-pointing triangle button on the projector for about 3 seconds. Once you see the RESET dialog, use the upward-pointing triangle to RESET. I can't see what you are or are not doing...so please see page 39 of the user's manual (download found below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-RX60-projector.html
Hitachi-CP-S335 :
"The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the lamp. Pressing the RESET button on the remote control for about 3 seconds displays a dialog. To reset the lamp time, select the RESET option using the (triangle) button."
Taken from pg 36 of the users manual (download link below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-S335-projector.html
Posted on Apr 24, 2008
projdoc
  • 2237 Answers
SOURCE: I need to reset the lamp hours on an Hitachi CP X380 projector
hold rown reset on panel for about 3 seconds, wait for display, press reset again and select 0.
Posted on Dec 23, 2009
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
I replaced the lamp, but am unable to reset the lamp so that the projector works again. It keeps giving me the message that I need to replace lamp and reset timer. And then it turns off.
1. Switch power ON, and press the TIMER button on the remote controller, or the RESET button
on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear
on the lamp timer on the bottom of the screen.
2. Press the MENU button on the remote controller, or the RESET button on the control panel,
while the lamp timer is displayed. The 'LAMP xxxx ? 0 CANCEL' message will then
appear.
3. Press the and select 0, and wait until the timer display is cleared.
Feb 18, 2011 | Hitachi CP-X270 Multimedia Projector
Fan running but the lamp is not on, I have
Hello :
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Apr 12, 2010 | Hitachi CP-S225 Multimedia Projector
I replaced the old lamp with new very carfuly and exact same way but now im getting a red light on in power and lamp and no light from lamp,is there a in fuse or something? what could be wrong?
Often a lamp reset procedure is required as well as changing the lamp over. not sure for the hitachi's (check Manual) over models often requires holding poweer button while plugging into power to reset the counter.
Dec 17, 2009 | Hitachi (DT00401) Projector Lamp for...
Need to clean air filter
clean the filter of your unit by pulling it fromt he unit...then after cleaning it...reset the filter counter fromt he menu settings and turn off your unit for about 5 min and there you go turn on your unit
Oct 28, 2009 | Hitachi (DT00401) Projector Lamp for...
Mar 24, 2009 | Office Equipment & Supplies
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Hitachi CP-S225
Hi Ian
Your Projector is in need of a new Mainboard.
Must warn you that it could be a costly exercise
Dec 06, 2007 | Hitachi CP-S225 Multimedia Projector
Hitachi CP-S225 Multimedia Projector Logo
979 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
