Question about Samsung SGH-E900 Cellular Phone
Java problem i downloaded super bluetooth on my samsung phone and i can go on it but when i go on connect and inquiry devices it just freezes
    Sergeant:
  • 218 Answers
This software is not for ur phone remove it from
Posted on May 23, 2008
Bluetooth is not working on nokia mobile 6233
To use the bluetooth,you may need to do the following:
1."Bluetooth"-power on
2."Inquiry audio device",this step aims at searching other bluetooth,then you can transfer information between them.
3."My device"-"inquiry new device"(this step is similar to the step 2,but there are some devices that you have inquiried in it,you can find the inquiried device which you want to connect easily)
4."Setting"-"Visibility "on/off,if you choose the option"on",then you...you can get much information in our website:Professional seller of Unlocked China cell phone
Have a good day!
Sep 14, 2009 | Nokia 6233 Cellular Phone
Tip
How to connect Bluetooth GPS using mobile phone
<p>Once I explain how Bluetooth GPS receiver to connect from a mobile phone. Bluetooth GPS Receiver is a device that continuously transmits its position (longitude, latitude and speed) using the Bluetooth protocol. If your phone is Bluetooth-enabled phone, you can connect to a Bluetooth GPS receiver to determine its position. To locate, connect to Bluetooth GPS and mobile phone to get the NMEA sentences for location tracking, you can also program a Java (J2ME) for your phone. Your program should do the following tasks: <br /> <p><br /> <p>1. Bluetooth device within the search area. Each time a Bluetooth device is discovered, discovery listener device Discovered trigger procedure. In the search is completed, the trigger listener discovery process inquiry Completed. <br /> <p><br /> <p>2. Get the name Bluetooth. We have a choice to a group list of Bluetooth-friendly name of the devices found to store. We also need a vector to devices found to store. <br /> <p><br /> <p>3. Select Bluetooth GPS receiver from the list of found devices. <br /> <p>4. Find service by the GPS device. Bluetooth GPS Receiver provides an L2CAP service so that the program needs to find this service for GPS url connection string for. <br /> <p><br /> <p>5. Get connection string from the GPS device. Connection string to the URL will have this format Url = "btspp: Address / bluetooth /:" + + L2CAP_UUID "permission = false; encrypt = false"; <br /> <p><br /> <p>6. Sign up and receive sentences from the GPS device. After plugging in the url in step 5, you can open the connection and extract sentences from the connection string. <br />
on Jun 26, 2011 | Cell Phones
Cannot install java on samsung i640
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
BUT THERE ARE SOME UNOFFICIAL METHOD PLEASE TRY THIS BUT RISK IS WITH U.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Jun 26, 2009 | Samsung SGH-i640 Cellular Phone
Installing java games to SAMSUNG E250
I finally succeeded in installing some java games to my Samsung E250 via bluetooth. I thought I would share the info on how I do it here because it seems to be a frequent unanswered question on various forums. You will need a *.jad and a *.jar file for your game. 1) Download Softick PPP and Samsung Java Uploader.exe . Also JADmaker if required. 2) Install SoftickPPP according to this Polish website. I don't understand Polish, but the pictures tell enough of the story. Set up your bluetooth COM ports in the SoftickPPP bluetooth/serial settings. My Bluetooth COM ports are either 24, 25 or 26. I leave them all ticked. 3) Enter *#52828378# on the phone to access the Java Test Menu. Choose OTA type setting, choose Serial bearer OTA. Click select. (This seems to need to be changed back to GPRS bearer OTA for Samsung PC Studio to connect) 4) Start SoftickPPP. Click on cancel for the missing USBPort.dll error message. Accept bluetooth connections for DUN and Serial connections on the phone. 5) Choose 'Activate PPP' by right clicking on the icon in the taskbar. Accept connections on phone again. 6) Start 'Uploader.exe' and then add the required jad file. Leave the program open. 7) If you are not still in the Java Test Menu then enter *#52828378# on the phone again. Select 'Serial test', 'PPP Up', 'Bluetooth' on phone, 'Serial download'. My phone sometimes restarts at this point in which case I have to choose 'Shutdown PPP" in the taskbar icon and then re-activating it once the phone has restarted and then re-do step 7 after entering the Java Test Menu again. A Java splash screen should appear with a progress bar showing the upload of the file. The game then starts automatically. There we go. It works for me Please man do you speak bosnian..
.Quote:
1) Type in the code *#9998*52824678255# (which reads *#9998*JAVAINSTALL# )
2) Your phone should return with 'Activated'
3) Now using Bluetooth or USB cable, connect to your phone (IR probably works too)
4) If you have a game as .jar, but don't have a .jad file, use JadMaker to create one (draw the .jar file to it and it will generate a .jad file for you).
5) Copy the .jar AND .jad file of the game into the map called "Other Documents" on your phone.
6) Now on your phone under 'My Files' browse to the 'Other Documents' map and doubleclick on the just copied .jad file.
7) The phone will ask you if you want to Install the game.
8) After Install you will find the game under Games on your phone.
9) You can now remove the just copied .jar and .jad file again (they were only there to install the game onto your phone).second answer:that i go to samsung company and when i ask them about jave install on samsung they say to me that the only way is to download from mobile internet games but it will be triall expet a game called 4*4 extreme race only and i tried to install any game it will be trial thanks for your reading (trusted)
May 22, 2009 | Samsung SGH-E900 Cellular Phone
How i can install java games in samsung sgh e250 via card reader problem:
I got a beautiful answr on d net surfn 4 yr questn ...
.Quote:
May 22, 2009 | O2 Samsung SGH-E250 Cellular Phone
How to install the super blue tooth hack on a samsung sgh-u600
20
Step outside the phone
Use Bluetooth wirelsess
Your phone is equipped with Bluetooth technology
which enables you to connect the phone wirelessly to
other Bluetooth devices and exchange data with them,
talk hands-free, or control the phone remotely.
From the Inbox:
1. In Idle mode, press <Menu>
and select Messages My
messages Inbox.
2. Select the MMS message ( ).
messages Email box.
2. Select Check new mail.
3. Select an e-mail or header.
4. If you selected a header, press
<Options> and select
Retrieve.
View an e-mail
In Idle mode, press <Menu> and
select Settings Bluetooth
Activation On.
and select Settings
Bluetooth My devices
Search new device.
2. Select a device.
3. Enter a Bluetooth PIN code or
the other device's Bluetooth PIN
code, if it has one, and press
<OK>.
When the owner of the other
device enters the same code,
the pairing is complete.
Turn on
Bluetooth
Search for and
pair with a
Bluetooth
device
All the above information came from:
http://www.samsung.com/me/support/productsupport/download/FileView.aspx?cttfileid=653066&type=&typecode=&subtype=&subtypecode=&cmssubtypecode=&model=SGH-D600&filetype=UM&language=ENGLISH&LSSI=/me/module/ssi/left/lmenu_mobilephones_gsm.sec&RSSI=/me/module/ssi/right/rmenu_mobilephones.sec
Artgirl
Jul 20, 2008 | Samsung Lands Phones
How do i download java applications to my phone
for that, u need to download the java games to your PC first.
after that connect to your PC through data cable or bluetooth.
start the samsung application loader software.
and rest u ll understand on your own.
thanks
Mar 20, 2008 | Samsung SGH-D820 Cellular Phone
Problems on games in samsung e250
To Install Java Games On Your Samsung-E250,You Have To Download "Softick" PPP and A "Java game Uploader"(search it on Google)..........
lnstall java games using usb data cable
SAMSUNG E250
Install\Run SoftickPPP221 from the Softick.PPP.v2.21 Folder. Ignore any errors about usbsync.dll by pressing OK.
Leave the option use usb in shared mode checked.
Run when finished installing. You will get an error message about being unable to locate usbport.dll, just click cancel.
Plug in your usb cable and turn phone on.
Right click on softickppp running in your taskbar and select settings.
In the usb tab uncheck accept ppp connection on usb and tick both use usb in exclusive mode and overide usb compatability,
Click on ok and completely exit softickppp by right clicking then exit.
Run softickppp and again goto settings. On the bluetooth\serial tab tick the correct com port.Mine is com3. Then click ok
On your phone key in *#52828378# press 2 ota type setting and select serial bearer ota.
Run samsung java uploader and add your jad file
On your phone select 3 serial test , 1 ppp up , 2 usb
Your phone will now reboot. While its rebooting right cklick on softickkppp in your taskbar and choose shutdown ppp
When your phone has rebooted again key in *#52828378#
Right click softickk ppp and activate ppp
On your phones java test menu press 3 serial test , 1 ppp up , 2 usb , 2 serial download
Your game should install and start running.
Oct 15, 2007 | Samsung SGH-E900 Cellular Phone
How to install games in smg e250
1) Download SoftickPPP and Samsung Java Uploader.exe from here. Also JADmaker if required.
Aug 16, 2007 | Samsung SGH-E900 Cellular Phone
Unable install games in samsung e250
Aug 04, 2007 | Samsung SGH-E900 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
