I HAVE NOT USED MY WII IN ABOUT 3 MONTHS I WENT TO USE IT TODAY AND IT IS UNABLE TO READ ANY OF OUR DICS IT IS TELLING ME TO CHECK THE MANUAL FOR TROUBLE SHOOTING I LOST THE MANUAL SO WHAT CAN I DO ABOUT THIS ISSUE?
It may be broke, It could of been broke when you got at the store to get it fixed go to WWW.videogame911.com or WWW.gamestop.com or take it back and where ever you got it you can ask then whats wrong with it.
Your Wii's laser needs to be cleaned or replaced. Sometimes even the spindle that spins the disc gets tight and needs to be replaced as well. We can certainly help you with this. Contact us today for a free quote.
- You've been helped by a Wired Extreme technician.
no u will probably have to take it to gamestop or something and c y it can not be read but in most cases it is just because of the dics try cleaning the dics and c what happens if that still dosen't work c if u can take it to gamestop
If Wii gives Disc Read Error, first step you need to check is to try another
disc or clean the exisitng disc. This will confirm that problem is with either
Wii or Disc. If the console itself is giving disc read error then it needs to be
repaired. You may check out DIY Wii Fix Guide, that
will show step by step information to fix the problem yourself. It also gives
information on fixing many Wii Related Problems, so its a kind of Wii Problems
Reference Fix Guide
another disc or clean the exisitng disc. This will confirm that problem
is with either Wii or Disc. If the console itself is giving disc read
error then it needs to be repaired. You may check out DIY Wii Fix Guide,
that will show step by step information to fix the problem yourself. It
also gives information on fixing many Wii Related Problems, so its a
kind of Wii Problems Reference Fix Guide
If Wii gives Unable to read Disc Error, first step you need to check is to try
Call customer service. It seems that some Wii's are scratching dics. The warranty will cover it. Look on the readable side of the disc and see if it is leaving circular scatches. Mine is doing the same thing to certain games.
