Question about Toshiba 52HM95 52" HDTV Projection Television
Taking out the color wheel
I was able to remove every thing out of the way but i still could not get to the color wheel to remove the top plate off,it would not slide out on the steel plate it is mounted on because its atached to a lot of wireing and there no way to get to the screws on top of the color wheel unless you can pull it out more which i could not any help please
    Problem Solver:
  • 4 Answers
Well, if you could hang on for a few hours, I could ask my husband. I know he had to pull all the little plugs out of everything and basically remember where they go after to put it back together. I know after unhooking everything, and undoing the plug wires, the whole piece slid out and then he was able to disassemble the casing and get to the wheel. Then he just used a lens cleaner cloth to clean everything. Let me know if this helps.
Posted on May 23, 2008
I need to replace the two top bearings on my 1982 Chevy Silverado K10, Tilt wheel steering column. How do I take it apart?
It is doable if you have the right pullers.
Take off the steering wheel (special puller)
Remove steering lock plate lock ring and plate(special puller)
Remove ignition key and tumbler
Remove T/S switch you should be able to get to top brng
Disengage tilt wheel spring
Take apart dimmer switch assy ( remember how it goes)
Remove 4 bolts connecting collar to steering shaft
Rotate collar upward to remove from shaft
With collar off, you can get to the lower brng.
Oct 31, 2013 | Chevrolet Silverado Cars & Trucks
How do i install a clutch in a 1982 datson pickup 4/4
front wheel drive or rear wheel drive ,reason i ask is i have changed many clutches in my time but now iam old i forget things ,but if its front wheel drive with the BMC morris B series engine then its easy to do and shouldnt take more than 15 mins to do as you only need to remove a plate on top of bellhousing then remove the spigot housing on the side and then undo each clutch bolt one at time whilst turning the flywheel ,so easy to do
Nov 05, 2010 | Datsun 720 Cars & Trucks
Picture freezes
a freezing picture is normaly due to bad input signal have your imp input signal checked
Oct 17, 2010 | Televison & Video
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
5
6
7
8
Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Install color wheel in samsung hlp tv model #hlp4663w
yes u need to take the optical block out is hold by screw umplug the hdvi cable and 2 small cable caming from the anolog board , now take the top black cover wicht is protecting the color wheel now remove the only 2 screw for the color wheel , becare full when remove the 2 smaller cable for the color wheel and when put it in the color wheel back in place
Jan 16, 2009 | Televison & Video
Color wheel/ Samsung
The Color Wheel (part# BP96-00674A) will run you just under $100 from www.samsungparts.com and they offer a variety of shipping methods which will increase your total amount spent. I just received mine today and I ordered it this past Sunday night. My HLR6167W started buzzing and gave me a black and white picture that morning and I was all over the internet investigating the symptom. I elected to go with the color wheel based on what I was seeing and all the different things I read up on. I plan on putting it in tonight and will let you know the difficulty surrounding its installation when I am done.
Jun 24, 2008 | Samsung HL-R6167W 61" HDTV
Help
who replaced it. to replace a color wheel most of the time you have to remove the light engine. sounds like they did get thing tighten down and lined up. take it back and tell them to line it up
Dec 19, 2007 | Samsung HL-R6167W 61" HDTV
Toshiba 52HM95 52" HDTV Projection Television Logo
91 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
