Question about HP Officejet J5780 All-In-One InkJet Printer
Printer problem It prints part of the page OK, the rest is weak, almost invisible.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Try to print a self-test page or make a copy from the all-in-one, if the results are same, then check the ink levels in the HP Solution center and replace the necessary cartridge .
Posted on May 27, 2008
One line prints light, the rest of the page is OK
Hi Charlie,
Sir/Madam
Go To Below Brother Youtube Video
Hope It's resolve all Your HP Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
Feb 06, 2014 | Brother MFC-8480DN All-In-One Laser...
First page of PDF files is printed in 10% size - rest of document is ok
Sir/Mam,
Does this happen with a word file, or a web page, or outlook, excel
please check. if OK with them its the file its bad. Mite want to upgrade the adobe to 10 or 11 current. Try different computer also. Print different adobe files also.
Dec 17, 2012 | Konica Minolta KONICA BR BIZHUB C451...
Invisible printing
Lost electricity to head micropiezzo (micro pump). Usually caused by ink leakage that flow to small board at head carriage. Better take to epson service centre. If you wish to repair yourself, find similar solution on aicaxz solution.
Feb 19, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
MY HP PSC 1315V WILL PRINT THE HEADER AND FOOTER OF PAGES I TRY TO PRINT FROM THE INTERNET BUT THE REST OF THE PAGE CONTENT IS ALMOST INVISIBLE
Most web pages are in color. Your web browser adds black headers and footers. I would suggest printing a test page to make sure the unit produces color correctly. If not, you can force the output to be in black and white, which should be legibile.
On Windows, go to Start>Settings>Printers and Faxes, then right-click on your printer and open the Properties page. There should be a "Print Test Page" button at the bottom.
Nov 14, 2009 | HP PSC 1350v All-In-One InkJet Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Prints a mostly black page
Check how the test page prints.
If it still prints bad.
Try reinstalling the printer driver.
It should be fine now.
Since the first two inches are fine, your printer looks to be fine.
The problem is only with the software.
Sep 26, 2008 | IBM Infoprint 1352 Laser Printer
Multiple page printing
To resolve this, do the following :
Windows 2000: Go to Start, Settings, Printers.
Windows XP: Go to Start, Control Panels, Printers and Faxes.
Right click on the printer icon and select Properties.
Click the Advanced tab.
Click the Print processor tab. The Print Processor screen appears.
Change the Print Processor to Winprint and change the Default data type to ENT 1.008 .
Click OK in the Print processor screen.
Click Apply, then OK.
Mar 07, 2008 | Lexmark P4350 All-In-One InkJet Printer
Deskjet HP 6940
this might be a software problem also. please specify which software you are using to print these banners. Thanks
Jun 12, 2007 | HP Deskjet 6940dt InkJet Photo Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
