Question about LG RZ-20LA70 20 in. LCD Television
LG RZ-23LZ40 no Picture
Used TV one night and turned off with remote. Next morning I have no sound or picture. Tried different input modes / setup / volume control to max still the same. Cannot even get the menu on the screen. Only thing working is the on / off red/green indicicator responding to remote control and push button on unit. Checked output voltages from switchmode supply to top board housing reciever and what looks like the main processor. 24v, 30v and 15v outputs all ok. Have not proceeded any further. Suspect that no sound is due to no channels are programmed as we do not use the internal tuner.
If you can help it would be much appreciated.
  • 2 more comments
  • cugar63 May 24, 2008
    Thanks Jaime867,
    This morning proceeded too take LCD screen apart. On, what I call, LCD driver board, found 2 OP Amps blown, one diode blown and one transistor severely over-heated to the point I cannot identify component number (burn marks on protective coverings etc). Probably a problem with power delivery circuit to LCD. I have pictures if you require for your log. I need schematics and or repair manual too determine source of suspected short circuit that overheated components, otherwise I will take a 5 year warrantee on my next LCD TV and not a LG brand! (2.4 years from purchase).
    I am now using an old TV that is 15 years + old...Panasonic! Good Japanese stuff made in China with decent quality control. Won't buy cheap again.
    I still would like to resolve problem and post to you for future LG suffer's.
    Thanks again
    Cugar63
  • cugar63 May 25, 2008
    sueandjohnnes@bigpond.com
  • cugar63 May 26, 2008
    Jaime867
    My fault not a name I usually use: sueandjohannes@bigpond.com
    Thanks for
    patience
  • yleon64 Jan 02, 2009
    My Lg 37LC3R'MH did the same what is the problem?
Hi Jaime867
I have sale Pb as
Can you send me service manual Spinnumber at Hotmail.com
Best regards
Posted on Sep 06, 2008
Thanks Jaime867
Best send repair manual.
I have pics to show / identify problem but I cannot attach to my reply. Parts defective are: 4532M x 2 (UC2 & 3), diode next to diode RC22 & cap C35 and IC6 (cannot see part number). Board number is YPNL-M007B r1.0, also recognized L.G. Phillips part number: LC230W01-A2
My hands are not as steady as years ago to do surface mount solerering but my wife can as she has done this before being electronic equipment assembler.
As stated before I need to find source of what I suspect is short that had blown these components.
I bet a replacement board is more expencive than a new LCD TV!, but I want to resolve this prob and maybe help others...LG too.
Thanks Heaps Jaime867!
Cugar63
Posted on May 25, 2008
  • 2,326 Answers
I would suggest to check the standby voltages as well. If the 5 volts are not present you will not get video or the TV will not operate properly.
Posted on May 23, 2008
  • 1 more comment
  • Jaime Hernandez May 24, 2008
    Let me know the reference designators of the parts you need, or even better i can send you the service manual if you need it.
    I have it.
  • Jaime Hernandez May 25, 2008
    I will need your email address to send you the service manual.
  • Jaime Hernandez May 26, 2008
    I tried to send you the service manual but it failed. I got the following message:
    Final-Recipient: rfc822;sueandjohnnes@bigpond.com
    Action: failed
    Status: 5.5.0
    Diagnostic-Code: smtp;550 Invalid recipient: <sueandjohnnes@bigpond.com>
Tv has sound but no picture, nothing shows with the flashlight test, all inputs have sound but no picture, installed a new t-con card with no results ?
Use a voltmeter to verify the different voltages on the power supply board are present within tolerance. Look for discolored , puffy or domed capacitors. Repair kits and complete replacement boards can be had from: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 17, 2016 | LG Televison & Video
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Hi, I have an LG RZ-20A70 TV and when i watch TV or play xbox the side are cut off the screen. (think its the picture ratio) any idea how to change this? as i have tried everything!
yes it is a picture ratio issue .
You need to look for the main menu tv setup button, its green on my lg remote .
Once you select this you should have an option to change screen ratio to 16.2 or wide screen if your tv supports wide screen .
Look for a little tv icon on screen and select that ,this should get you to pic set .
Jun 16, 2011 | LG RZ-20LA70 20 in. LCD Television
I have great sound on my tv but there is no picture
i had the same problem take the back off an unplug the lcd an give it a blow put bit all back together an fany's your ant
Apr 24, 2010 | Sanyo DP37647 37 in. LCD TV
Sound no picture
backlight invertor board/does it flash when powered on
Apr 20, 2010 | LG 32LB9D TV
LG 32LP1D TV no power
Check the fuse on the power board. If ok change the power board.
Nov 01, 2009 | Televison & Video
No sound on 50 inch hitachi tv
Have you checked other inputs with a known good program source? Mute button on remote?
Apr 27, 2009 | Hitachi Televison & Video
Sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LG RZ-20LA70 20 in. LCD Television Logo
1,153 people viewed this question
Computer Repairing
Computer Repairing
