Replacing a lifebook c series (c-4155) notebook hard drive..How To??
Hi.. How do I replace the hard drive on this notebook.
lifebook c series c-4155??
If you have a service manual or information on how to do this it woulod be highly appreciated thankyou.
Regards
Jason
  • pcpd May 23, 2008
    Hi. Dunno if Im using the right thing here to reply to youre help which is really appreciated, but Ive managed to sort the problem.
    So for any other users of this notebook here is the fix.
    On the back of the laptop, right at the back of the cd tray there is a small philips head screw.
    Undo this and the cd tray will now be able to be removed.
    Under the cd tray there is a small bay where the hard drive locates.
    Simple..problem solved...lol.. Figured it out after posting, so kind regards to people who have looked and to Vistapro for his advice.
    Many thanks
    Jason
    Problem Solver:
  • 6 Answers
Do you have a picture of the bottom of the laptop? if this dosen't help, can you post a picture? personally i don't have a lifebook and i really only know how to replace it if i can see it. i know with my toshiba satellite l10, on the bottom there is a symbol of a laptop, on the bay of the hard drive casing. if you undo the screw on the bottom of this bay, yo will be able to see the hard drive, in most cases 150mm x 100mm x 10mm and silver and compact. i you slide this out and put the matching hard drive in, and match up the pins, carefull not to break or bend any.
Hope this helped,
Regards,
Vistapro
Posted on May 23, 2008
Dropped Fujitsu Lifebook A1110 wont boot past the repair mode screen. The hard drive is connected. Any advice will be appreciated. Thank you!
Sound like the hard drive is gone my Friend. Going to have to get it replaced. The best thing I can tell you is get another PC or laptop install Linux maybe Unbuntu or one of those flavors. Use the hard drive retrieval method and moves as much UN-corrupted data as possible...when you do that let me know and I tell you how to take out your hard drive. And replace it ...if you don't know how to do the retrieval please email me at d1r7yp4w5@gmail.com and I tell you step by step. Through email...goodluck
Dec 18, 2011 | Fujitsu LifeBook A1110 Notebook
Need an owners manual for fujitsu lifebook s6000 notebook
Here's a link where you can download the manual for your Lifebook. Though you need to specify the exact model. (ex: S6110, S6120 etc)
http://support.fujitsupc.com/CS/Portal/support.do?srch=GUIDES
Select "Notebook PC" under the 'product', "S series" under the 'series' and the exact model of your Lifebook under the 'model' box.
Hope this helps.
Sep 09, 2011 | Computers & Internet
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
How to replace hard drive
dont mess with it take it a pro
Apr 30, 2010 | Fujitsu LifeBook Notebook
Hard drive info for Fujitsu T4210
Better late than never. See http://simshsia.wordpress.com/2008/07/15/disassembly-of-the-fujitsu-lifebook-t4200-series-tablet-pc/
I hope this helps. Should you have the original system restore disk ( or copy ), kindly get in touch.
Nov 03, 2009 | Fujitsu Siemens LifeBook T4210 Notebook
Looking for a hard drive for my lifebook c series
Pull the BIOS battery.
Check all drives for non system floppy or CD before yo go to this trouble.
I hope this helps
a
Oct 06, 2009 | Fujitsu LifeBook C6581 Notebook
Need to replace fan
www.insidemylaptop.com/replace-fan-fujitsu-lifebook-t4200-tablet-case/
i think this site will be enough to know instructions to replace it
Jun 19, 2009 | Fujitsu LifeBook S7010D Notebook
Display problem in Fujitsu LifeBook C Series(c-6631
the internal bulbs of ur monitor screen have deteriorated...the manufacturers are real smart, these monitors dont last forever. So if repair estimate is too expensive then replace the whole unit.
Always purchase laptop or notebooks NEW or never more than 5 years old.
May 24, 2009 | Fujitsu LifeBook C6631 Notebook
How do I remove a hard drive from a fujitsu lifebook T 4020 ?
underneath the laptop will be access panels, unscrew them and remove, the hard drive looks similar to this 95631bb.jpg
Nov 24, 2008 | Fujitsu Siemens LifeBook N3010 Notebook
Computers & Internet Logo
705 people viewed this question
David Payne
David Payne
