My acer laptop with windows xp will not allow me to select the optimal resolution for my samsung moniter. How do I fix this?
  • 1,031 Answers
The Samsung SyncMaster 730b is a 17-inch analog and digital TFT-LCD monitor delivering crisp, clean text and bright, vivid colors. This display offers a 600:1 contrast ratio, 300 cd/m2 brightness, 1280 x 1024 resolution, 160/160 degree viewing angle, scanning frequency of 30-81 kHz horizontal and 56-75 Hz vertical and 0.294mm pixel pitch
The SyncMaster 730b display offers the option of using either a digital or analog interface for viewing images and text. The Digital Video Interface (DVI) ensures a shaper, cleaner image and a more accurate representation of the original video source. Since video starts out digital in a PC graphics card, the digital output is directly interfaced to the digital input of the LCD panel and always provides the optimum quality image. In addition, no adjustments are required with a digital display, even when randomly changing resolutions. Input connectors for this display include 15-pin D-sub and DVI-D. Available in black, the SyncMaster 730b delivers a maximum of 16.2 million colors. The monitor is Windows Plug and Play DDC 2B compatible
The important stuff here would be the following:
(1) 30-81 kHz horizontal and 56-75 Hz vertical
(2) SyncMaster 730b delivers a maximum of 16.2 million colors
(3) 1280 x 1024 resolution
nVidia card settings should not exceed these monitor parameters. The monitor is not designed for more performance output without increasing liability toward failure. ?. Put your card settings, under the nVidia tab, at the following:
(a) Refresh rate set at 75 Hz
(b) Set colors at 16 million
(c) Set resolution slightly less than 1280 x 1024
It?s quite possible your monitor is at fault, but start with its optimal parameter settings for the display card first. The display card probably exceeds the monitor?s capabilities. Hopefully, this will stabilize your PC session and the blank outs cease if hardware is not faulty
Posted on May 23, 2008
I have an acer aspire5517, when I turn it on i see the windows 7 startup screen, then just all black. After about 30 secondsmy screen savercomes on, as soon as i move the mouse it returns to a black...
might have the resolution set higher than the LCD will display. at boot press F8 select Enable Low Resolution mode, and see if you get a desktop, if you do, then adjust the screen resolution to optimal and reboot
Aug 08, 2011 | Acer Computers & Internet
My samsung syncMaster 753s moniter does not support resolution of xp what i do further
Your monitor can easily support Windows XP resolutions. The problem almost certainly lies in your video settings. You need to lower your screen resolution and/or refresh rate.
If you can not start Windows due to this problem, you will have to start Windows in VGA compatibility mode. Follow these steps:
  1. When your PC starts up, press F8 a few times
  2. This will bring up a menu whereby you can select VGA mode from the list
  3. Once you are logged into Windows, right click anywhere on the desktop & select "properties"
  4. Then go to display settings & select a resolution of 1024 X 768.
  5. Go to advanced settings and make sure your refresh rate is no more than 70 to 75Mhz
  6. Restart Windows normally & your display should be correct.
Let me know if you have any further questions.
Best wishes,
Graemevm
Mar 30, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Input Not Support
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears. If you use Windows Vista oder Windows 7 you can access the resolution windows by right-cliking on your desktop and selecting "Screen resolution".
Jul 18, 2010 | AOC 19LVWK LCD Monitor
My screen goes off when windows xp starts the boot process
Does the display come back at all?
Is it the same on an external monitor?
As soon as BIOS screen disappears press F8 multiple times until a text menu appears allowing you to to select SAFE MODE. Select SAFE MODE.
DO you get a display now?
Can you select 1024x768 resolution and get a display, if so, rebot and try a normal boot.
May 16, 2010 | Acer Computers & Internet
I just purchased a acer moniter ...I plugged it in and the picture looks a little distorted (my grand daughter says I am not use to the new flat screen) on the moniter was a film cover that said make sure...
If your on XP you can right click on the empty desktop and go to properties, Under the settings tab you will find options for screen resolutions. If your on Vista or 7 you right click on empty desktop space and go to screen resolution, There again you will easily find your settings for your screen resolution. Click apply and then click OK after that lay back and enjoy your screens clarity.
Apr 25, 2010 | Acer X183HB Monitor
The display randomly got larger and i can't make it smaller again.acer 4520
well, if you're using windows xp, right-click your desktop and click properties, then raise the resolution from the bar on the bottom, and presto! you're done, it's similar if you're using Vista, right-click your desktop, click personalize, then display settings, and raise the resolution, hope i helped.
Jan 18, 2010 | Acer Aspire 4520-5803 Laptop
ACER AL 1717 (Dispaly massage INPUT NOT SUPPORTED) ? OS: WIN XP sp2
i think the probelem is monitor resolution out of range . connecte the system other moniter and chage resolution then try .80% problem is fixed or other probelem is monitor hardware falier
Jul 18, 2009 | Acer AL1717 17" LCD Monitor
Instructions for use acer aspire5050-5430 notebook orbicam
These are the text-only instructions:
Launching the Acer OrbiCam
To launch the Acer OrbiCam, double-click on the Acer OrbiCam logo in the
desktop.
OR
Click Start > All Programs > Acer > Acer OrbiCam. The Acer OrbiCam capture
window appears.
Changing the Acer OrbiCam settings
Resolution
To change the capture resolution, click the displayed resolution at the bottom
right corner of the capture window, then select the desired resolution.
Note: Setting the camera resolution to 640 x 480 or larger does
not change the capture window size.
33
English
Options
Click Options to display the Window, Preview, and Folder tabs. Use the options
to change the capture window size, preview settings, and the folder for
captured photos or videos.
Camera Settings
Basic settings
Click the Camera Settings icon on the bottom right corner of the capture
display, then select Camera Settings from the pop-up menu. You can adjust the
Video, Audio, and Zoom/Face tracking options from this window.
34
English
Capture settings
From the Camera Settings window, click the Driver Settings button. The
Properties window appears.
Device Settings allows you to change the camera brightness, contrast, hue,
saturation, sharpness, etc.
Advanced Settings allows you to activate gain control, implement image mirror,
select image enhancements and anti-flicker settings, and turn on/off the camera
indicator.
Zoom/Face Track Settings allows you to adjust the zoom level and turn the
face-tracking feature on or off.
Capturing photos/videos
To capture a photo or a video clip, rotate the Acer OrbiCam to get the desired
angle, then click the Take a Picture or Record a Video button. The Windows
Picture and Fax Viewer or the Windows Media Player automatically launches to
display/play a preview of the photo/video clip.
Note: By default, all photos and videos are saved in the My
Pictures and My Videos folder.
Using the Acer OrbiCam as webcam
The Acer OrbiCam is automatically selected as the capture device of any Instant
Messenger (IM) application. To use the Acer OrbiCam as a webcam, open the IM
service, then select the video/webcam feature. You can now broadcast from
your location to an IM partner anywhere in the world.
Jun 10, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
