Question about Acer TravelMate 354TE Notebook
Keyboard locked out for microsoft word 2003
Heya i recently installed Microsoft Word 2003 on my Travelmate and used it no problems for a few weeks, but now the keyboard is disabled within the Word programme, and it says i`m unable to alter this document. Is there a keyboard lock or function that i may have triggered inadvertently? The keyboard is fine for every other application. Cheers, Dave
    Scholar:
  • 110 Answers
It's not the keyboard. If it was, it wouldn't work in anything.
It's possible that the "normal.dot" template is protected. This will result in any document created using that template also being protected. Try going into File -> New and creating something specific, for example a menu, that uses a different template. If suddenly you can use the keyboard, then you've found the problem.
Under those circumstances, use the Windows Search tool to find the file "normal.dot" and delete it. When you run Word again it will create a new, unprotected document template called "normal.dot" and Word should function correctly from then on.
Posted on May 26, 2008
F12 function key doesn t work
Function keys are special keys used for assigning program shortcuts and specialty tasks to the keyboard.
They are located at the top of most keyboards and labeled "F1" through "F12."
Some keyboards may only feature 10 function keys, while others may have as many as 18. These keys often go unutilized by the average computer user, but they may have very important tasks for some users, which can lead to problems when the keys do not respond.
Fixing nonresponsive or malfunctioning function keys is quite simple, and should only take a few minutes.
Connect your keyboard to your computer, and power it up.
Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key.
This key is used to toggle function-key support; when it is toggled on, the function keys will not work.
Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software.
If the key does not work, press the "F-Lock" key a second time, and test the keys again.
If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality.
Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.)
Some function keys or keyboard shortcuts do not work correctly on a computer that is running Windows 7
http://support.microsoft.com/kb/975741
Resolve unexpected Function (F1 - F12) or other special key behavior on a Microsoft keyboard
http://support.microsoft.com/kb/894513
Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database.
Agree to the terms and conditions, then download the hotfix.
When the download is finished, run the downloaded file and follow the on-screen instructions.
You may need to restart your computer after the installation is complete.
Your function keys should now work properly.
Jul 14, 2013 | Dell Computers & Internet
My fn button wont work
Jun 27, 2013 | Packard Bell Computers & Internet
Why wont my fn button
My Samsung laptop's (np-r430-jb01ae) function keys are not working. how could i solve it?
Step 1:
Function keys are special keys used for assigning program shortcuts and specialty tasks to the keyboard. They are located at the top of most keyboards and labeled "F1" through "F12." Some keyboards may only feature 10 function keys, while others may have as many as 18. These keys often go unutilized by the average computer user, but they may have very important tasks for some users, which can lead to problems when the keys do not respond. Fixing nonresponsive or malfunctioning function keys is quite simple, and should only take a few minutes.
Connect your keyboard to your computer, and power it up. Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key. This key is used to toggle function-key support; when it is toggled on, the function keys will not work. Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software. If the key does not work, press the "F-Lock" key a second time, and test the keys again. If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality. Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.) Some function keys or keyboard shortcuts do not work correctly on a computer that is running Windows 7 http://support.microsoft.com/kb/975741 Resolve unexpected Function (F1 - F12) or other special key behavior on a Microsoft keyboard http://support.microsoft.com/kb/894513 Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database. Agree to the terms and conditions, then download the hotfix. When the download is finished, run the downloaded file and follow the on-screen instructions. You may need to restart your computer after the installation is complete. Your function keys should now work properly.
Feb 25, 2013 | Computers & Internet
Hotkeys not working properly
Connect your keyboard to your computer, and power it up. Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key. This key is used to toggle function-key support; when it is toggled on, the function keys will not work. Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software. If the key does not work, press the "F-Lock" key a second time, and test the keys again. If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality. Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.) http://support.microsoft.com/kb/975741 Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database. Agree to the terms and conditions, then download the hotfix. When the download is finished, run the downloaded file and follow the on-screen instructions. You may need to restart your computer after the installation is complete. Your function keys should now work properly.
Feb 09, 2013 | Samsung Series 7 Chronos
Service pack 2 installation problem(product key) for windows 2003
Try reentering the product key
Call microsoft and verify that your version is authentic and not pirated...
I had this problem already and it turned out althoug i had an authentic version the key i was sold with the cd was not recgoinised by microsoft. After providing my proof of purchase microsoft gave me a new key
Jul 10, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Wireless Optical Comfort Desktop and Mouse combo Freezing Prob.'s
have you tried pressing the connect button on the reciever then on the mouse so it picks it back up again?
May 01, 2008 | Microsoft Multimedia Optical...
Acer TravelMate 354TE Notebook Logo
417 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
