Question about Acer Aspire 5100-5022 Notebook
How to remove windows vistra from a acer extensa 5220 and replace with windows xp
    Problem Solver:
  • 10 Answers
Use this program called kill disk it kills evey thing on your HD i did that it works for me make sure your windows cd is bootable
Posted on Jun 23, 2008
Oo, Acer Extensa range is perfect for home and office!!!
I had <a href = "http://chmochnish.nov.ru/eng/">problems when I install Windows XP on Acer Extensa 5220</ a>.
I found help on website http://chmochnish.nov.ru/eng/
all you need is <a href = "http://chmochnish.nov.ru/eng/Acer-5220-xp.php">windows xp sata driver for acer`extensa 5220</ a>
Article: <a href = "http://chmochnish.nov.ru/eng/Acer-5220-xp.php">haw to Install XP on Acer laptop 5220</ a> is full howTo!
Posted on May 26, 2008
    Genius:
  • 1,066 Answers
If i were you, id pull the original hard drive, and install a fresh hd before installing xp, because xp may not support all your hardware, which would force you to revert back to vista; in which case, you may regret removing vista from the drive.
you could simply boot from the xp disk , and let it overwrite the disk then install itself, however, i dont think xp automatically formats before install, id prolly install alongside vista, which may require you to enter a dual boot option command line, refer to microsofts website on dual boot systems)
if your using an xp upgrade disk, youll have trouble, it wont allow you to upgrade from a newer version of windows.
Posted on May 23, 2008
  • 57 Answers
HAVE A VALID REGISTRATION KEY for WINDOWS — Microsoft will not let you upgrade your operating system with necessary patches until you VALIDATE your copy of Windows XP - by phone or online. If you try to update or format your system with a shared or borrowed copy of Windows XP, your result may be a crippled or non-working copy of Windows XP on your computer. You’ll need that 20 character number from your Windows Certificate of Authenticity. A certificate of Authenticity looks like the image below:
how to remove windows vistra - coa.jpg TO BEGIN:
1 ) Put the installation CD of XP or Windows 2000 into the CD drive and start the computer. Your computer should display “Press a key to start from CD”. You must boot from the CD because you’ll need to format the C: drive partition where Windows is installed on the hard drive.
If your computer is displaying a blue screen with white text, then you can proceed to step #2.
Your computer’s “Boot Order” tells the computer which device to check first when starting the computer. If your computer did not boot from the CD, you’ll need to power on your computer and press either the F2 or F10 or Del key — depending on your computer — to display your computer’s BIOS menu. In the Bios Menu, find the menu that allows you to change the “boot order” and make a change so that the computer will boot from the CD first, instead of the hard drive.
2 ) A blue screen with white text will be displayed. Press F8 to accept the Windows XP Licensing Agreement. The Windows XP Setup program will search for existing Windows installations and “repair or install fresh copy” will appear if a Windows installation currently exists on your machine. Press [Esc] (don’t repair).
3 ) A list of your computer’s disc partitions will be displayed. Press the UP or DOWN arrow keys to choose your main install partition. Note that your system partition must be a primary partition (usually the first partition that appears in the list), not a logical partition.
4 ) Once you have selected your main partition, press ENTER. “You already have a system installed” will be displayed if you already have Windows installed on this partition.
5 ) Press C to continue. From the options displayed, select “Format the partition using the NTFS file system” then press Enter. Windows XP can also run on FAT32, but the NTFS file system is recommended because it is more stable. You will receive a warning about formatting the drive unless the drive is brand-new -Press “F” to confirm you know that you will be formatting the drive. The disc formatting may take a while depending on the capacity of your hard drive.
6 ) The Windows XP install should begin automatically after the formatting is complete. If not, restart the computer with the Windows XP CD in the drive and follow the instructions for installing Windows XP. This can take 35 minutes or more depending on the speed of your computer.
7 ) Once Windows XP has been installed, connect the computer to the Internet, start the Internet Explorer browser, and visit http://update.microsoft.com/windowsupdate to download and install the latest security patches and updates for your operating system. This could take up to an hour depending on the age and version of your freshly installed copy of Windows XP. When I did this last week, there were 79 security patches for the version of Windows XP that I installed.
8 ) Install the sound, video, modem, and other drivers that are specific to your computer and your operating system — as mentioned in the very first step. Follow the instructions as provided by your computer manufacturer. You may be told to restart your computer between installing some drivers according to your manufacturer’s directions.
9 ) Restart your computer, then select “Start > Help and Support” Click any update links you see to install the latest patches and drivers from Microsoft and from your computer manufacturer.
That’s it. Good luck!
HOW TO CONNECT A HP MONITOR TO AN ACER EXTENSA 5220 LAPTOP
Plug the VGA lead from the monitor into the laptop and power the screen up then the laptop. Select external screen on your laptop.
Sep 18, 2014 | Acer Extensa Computers & Internet
ACER Extensa 5220 no audio from speakers
redownload it
enter a valid model number..
Mar 10, 2010 | Office Equipment & Supplies
I cant format my acer Extensa 5220 with XP please help me sss17asmar@yahoo.com
Please use the windows installation cd or the restore cd's that came with the computer to restore / format the machine.
Jul 12, 2009 | Acer Aspire T310 PC Desktop
Problems with the built in wireless on my acer extensa 5220
Yes, you will need drivers for your wireless card.
You can download them here.
Jan 15, 2009 | Computers & Internet
My acer extensa 5220 laptop WiFi not working; device manager shows Ethernet controller need software, "Found new hardware" notification sometimes apear
You should download a wifi card driver and install it from this location:
http://www.laptops-drivers.com/acer-notebooks/download-acer-extensa-5220-for-windows-xp.html
Jan 09, 2009 | Computers & Internet
Acer Extensa 5220 Bluetooth Problem
Hey, all the drivers are available on this page
http://support.acer-euro.com/drivers/notebook/as_5220.html
if you still have a problem drop me a ask me request / free. or comment and explain here.
Thanks
Sep 15, 2008 | Acer Extensa 503T Notebook
I can't find any driver support on acers web site for my extensa 5220 as it doesn't seem to be listed in their product drop down menu. Are their any sites that cater for this type of note book?
Hello there,
Here is the direct link to your drivers. Make sure you download the drivers for the operating system you are using (either xp or vista)
Enjoy!
Lolita
Apr 17, 2008 | Computers & Internet
Acer Aspire 5100-5022 Notebook Logo
347 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
