Question about Fuji FinePix S8000fd Digital Camera
Lens adapter needed
I have fujifilm S8000fd camera. Now I want to add a lens adapter barrel in it ,which can help me to add extra filters and lenses with it like in the SLR.But I can't find any threads around the lens barrel to attach the adapter.Please anybody can help me?I really need this badly.
  • Anonymous Jan 06, 2009
    I need a lens filter for my S8000fd fuji camera
Get yourself a step ring, 52mm for you S8000FD, this has a thread on the end and allows filter attachments. I have an S8000FD and have since bought a step up ring, UV filter and Polariser, plus another lens cap which fits on to the end via a pinch mechanism rather than clamping like the one provided by Fuji.
Posted on Jan 22, 2009
Sorry but there isnt one - and they are not planning to make one either.
I haver looked.
Posted on Aug 14, 2008
Can i change the lens of my camera model Fujifilm FinePix HS10
While you may not be able to remove the fixed lens on this camera, you can still add other lenses on top of it, like a telephoto or wide angle lens. An example of lens accessories you may purchase for this model can be found here.
Mar 25, 2011 | FUJIFILM FinePix HS10 / HS11 Digital...
When i turn my fujifilm finepix s8100fd camera on the lense will pop out as normal initially then the screen will say lense error, and the camera will make a funny noise and the lense will go back in, it...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 28, 2010 | Fuji FinePix S8100fd Digital Camera
Zoom error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Apr 21, 2010 | FUJIFILM Fuji Finepix S Series 4GB Deluxe...
How to install fisheye lens and adapter on kodak dx6490. Do I have to remove existing AF lens
No, you do not remove the existing lens. You need to purchase a lens adapter tube that fits around the existing lense. This adapter threads onto the inside bezel on the camera at the base of the lens assembly. Additional converter lenses and filters fit onto this. My adapter has 55mm threading for filters.
Oct 08, 2009 | Kodak EasyShare DX6490 Digital Camera
I want to add lens to my fujifilm s5600 to take better pics
There are lenses available to add with an adapter ring. I have the wide angle lens (which I LOVE) and a 2x telephoto lens. The wide angle lens allows me to macro from several feet away. It is an amazing lens. The telephoto lens is something you really need to use with a tripod. But yes, there are lenses you can add to your camera.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Conversion lenses & filters
These screw on the front of the plastic lens adapter and adjust the focal length. On the side of the adapter lenses it will quote the ratio. My wide angle says 0.66x so just multiply the range of focal lengths by this figure and you will see that it adjusts the camera zoom accordingly - making the image wider and probably also increasing the depth of field (what is in focus). Similarly a 1.5 tele will inrease the range of focal lengths to make the lens "longer" eg higher magnification , useful for astro photography - shots of the moon and terrestrial long distance work but detracting from the depth of field, eg the range of distance over which objects are in focus will be reduced.
The wide angle will allow you to come in close and get WIDE objects fully in-frame- hence "wide angle", while the telephoto will give you better overall maginification of the image but will probably increase the MINIMUM focal length - eg you may not be able to focus on objects closer than >2m (instead of ~1).
The screw-on adapter lenses I found were cheap in a Jessops sale use a 52mm thread, while the S5500 provides a 55mm internal thread. I use an appropriate 55mm to 52mm step down ring adapter. There is slight vignetting (shading around the edge of an image) at certain combinations of zoom, but generally these are very useful accessories.
As these are adapter lenses on the front of an already powerful 10x zoom that must be optically compromised at the price of this camera, there maybe some colour fringeing around bright images. If you want a better solution you really need to get a DSLR. Overall a good solution for the price.
Sep 17, 2008 | Fuji FinePix S5500 Digital Camera
Minolta maxxum 300si (Filters?)
Hey sunnibeach4,
On SLR cameras the filters are attached to the end of the lens via threads inside the end of the lens barrel. Without knowing exactly what lens you are using I can't tell you what filter diameter you need but most lenses list that information on the inside rim of the front of the lens. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 08, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Lens adapter
Hi
I do not believe that it is possible to use a lens adapter with this camera or even filters.
The lens that comes with it has a wide focal range and the camera itseld is sold as a compact.
You may need to look at a fully digital SLR to get this feature
Apr 22, 2008 | Fuji FinePix S8000fd Digital Camera
Lense adapter and extra lenses for fuji finepix E900
There are several of what you are looking for on eBay. They are slip on to fit the E900
Jan 04, 2008 | Fuji FinePix E900 Lens Adaptor Ring Lens...
62 size
If you want to add other lenses, either macro, wide angle, telephoto or just filters, they go directly on the adapter. That's why the thread size (62mm) is important because that's the best fit for that adapter. If you get other sizes you can still use them with step rings but that adds to the expense and stepping down can cause vignetting. In case you were wondering, here is a link to the Phayee auction: http://cgi.ebay.com/... ...wItem&rd=1&item=3865219929&ssPageName=STRK:MEWA:IT
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Fuji FinePix S8000fd Digital Camera Logo
237 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
