Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
Loose USB connection in laptop
Hi I have a compaq presario 2500 and when I connect a memory stick to the usb connection it is very floppy and loose. How do I open the laptop to secure
  • 868 Answers
You can't do that repair unless you are a experienced circuit tech.
Posted on May 26, 2008
Pxe-e61: media test failure, check cable acer extensa 542
Your computer tries to "boot" from several devices:
* floppy disk
* CD/DVD optical device
* disk-drive
* external CD/DVD
* USB memory stick
* PXE ("Pre eXecution Environment)
To use PXE, you need "media" -- a network cable connecting yur computer to a "boot-server". The "media test faiure, check cable" reports that no network-cable exists, or that it does exist WITHOUT being connected to a boot-server.
Probably, your computer failed to boot from a DEAD disk-drive, and then tried floppy/CD/USB before checking PXE.
Replace the disk-drive.
Jul 30, 2012 | Compaq Presario-Notebook 700 Series, 2500...
Compaq presario cq57 PCI drivers
Use a computer with Internet access to download the drivers and then copy them to an USB memory stick. You then insert the USB memory stick inti your Compaq and install the drivers.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Feb 23, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
My Compaq Presario C700 laptop usb ports are over heating, so im trying to open the laptop to see if a wire is loose how do i do this???
The ONLY reason those ports would overheat is because you are trying to connect too many USB devices to them. If you are using a USB expander then you need to use it WITH the external power supply it came with, OR, be sure the batteries are good if it is battery powered.
You also might have a bad wire or printer etc...but thats not very likely!
Feb 19, 2011 | HP Compaq Presario C700T
My ccd-u mouse has stopped working.mouse came with floppy disc so can,t down load driver to my laptop, it was working ok but then stopped thanks
FInd a computer with a floppy-drive and a USB port.
Insert the diskette, and copy all the files to a USB memory-stick connected into the USB--port.
Move the USB memory-stick to your laptop, and connect it.
Access the device-drivers on that device.
Nov 21, 2010 | Computers & Internet
Hi! i got a mobile presario compaq presario
What kind of device are you trying to connect. If it is a hign amp device like old external HDD, it could cause he issue. In such cased connect both the USB pins provided to facilitate more current flow.
Also check the status of USB from device management. No warning symbol should be displayed.
Please come abck and rate for my solution if it turned to be helpful for you.
Thnx :)
Mar 22, 2010 | Compaq Presario C700T Notebook
Compaq Presario CQ70
most likely one of your hinges have broke. remove the bezel you might just need to tighten the screws that hold the brackets to the hinges. you can order all the parts and easy fix
Jan 22, 2010 | HP Compaq Presario CQ70-120US Laptop
Compaq Presario S5200NX will not recognize memory stick
is either you reload the computer system or u buy an internal or external usb card.or check the connection cable inside the computer machine if it is properly connected
Jan 16, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Compaq Presario 2500 USB Problem
go to control panel -device manager and see if you have all the latest drivers downloaded and if u dont then i would try and update them. if that doesnt work search up the specific driver u need online and download and install it.
Aug 10, 2009 | Compaq Computers & Internet
How do i have a usb port run a high speed device
The USB port in your computer is not the new high-speed USB 2.0 version, and when you plug a USB 2.0 device in you will get that message. Most USB devices will still work but not give best performance. Just close the message window.
The network cable unplugged message can be disabled through the network settings. Normally Windows is set to display that message when there is no network cable connected. You can just ignore the message.
Dec 09, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 2500 (2598us) loose keyboard
You might want to check the keyboard connection. It sounds as if it's not connected or seated properly.
Aug 20, 2008 | Compaq Presario 2598Us Notebook
Computers & Internet Logo
298 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
