Question about Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher
Hotpoint dishwasher bci450
When i put on the dishwasher it bleeps and switches to the eco light. it sounds as if it is washing but it isnt. the washer is only 20 months old. it had a new pump when it was 11 months old. what can i do without paying hotpoint a fortune to come and look at it again.
  • 57 Answers
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
Posted on May 23, 2008
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dishwasher fdw60
the fault wasn't with the machine. we got new waste pipes put in and the conection for the dishwasher hose didn't have the hole for the water to release. thank you for your help
Jul 15, 2008 | Hotpoint Dishwashers
Dishwasher just draines and nothing else??
this sounds like it could be the heater element has gone faulty, it is quite difficult to get to test it with it being built in, but basically gain access to the underneath of the appliance and you can test it with a test meter for open circuit, it is also possible that a wire has either come off or broken, the pump pumping out is like a safety mechanism, the eco wash may work because this uses no heat? (some models) the answer i have given you is based on the info you have supplied if i have helped please rate me, thank you, please work safe unplug when working on appliances
Sep 22, 2007 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher Logo
1,127 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
