Question about Indesit W 123 Front Load Washer
INDESIT 1000 DOES NOT START
LOAD WASHER DOOR LIGHT FLASHES BUT WHEN PRESS START - IT DOESN'T!! DOOR LIGHT JUST KEEPS FLASHING
  • 57 Answers
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
If this doesn't work you may have to replace the EMW. Should cost you around 60$
Posted on May 23, 2008
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
My front load affinity will not start, says pause
Hello friend, thank you for your post!
I see that your Frigidaire washer, FAFW3517KW, is constantly showing you pause, when you press start it flashes the pause again, and that the door lock light does not come on. You could be seeing a couple of different possible reasons this is happening such as your control panel, door lock assembly, or door switch. Since it could be any of the underlying issues I would recommend having a professional come out to the home and repair the washer. -Matt
Aug 02, 2014 | Frigidaire Affinity FAFW3517KW 3.5 Cu. Ft....
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Indesit wil 153 door red led is flashing after I set washer settings, doesn't start cycle ?
The flashing light means that the machine thinks the door is not closed (The door lock switch is not activating). 99% of the time this is simply a sticky switch and the solution is to give the door a good firm slam shut (Don't get silly here, but it will take a pretty good "teenager slamming the bedroom door in a temper tantrum" type slam).
In the event that this doesn't work, then you're looking at a faulty door interlock switch. They're not that hard to obtain or fit if you're fairly confident. Drop me a comment back here and let me know how you get on. Happy to help further if the above hasn't allowed you to solve the problem.
Aug 15, 2011 | Indesit W 123 Front Load Washer
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
1,459 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
