Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Refrigerator Freezing I have the dial set below #1 for the refrigerator and everything inside is freezing. What should I do?
  • 91468Mickey May 24, 2008
    Kenmore GSI-26 Yes It is Frost Free about 4-5 Years old.
  • 828 Answers
What is the make and model number of your refrigerator? Is it a frost free unit? How old is it?
Posted on May 23, 2008
  • James Helmer
    James Helmer May 24, 2008
    You then most likely have a malfunctioning thermostat control for the refrigerator temperature. Name plate is located on lower refrigerator door frame. You can order a new control by model number (CAT number) from Sears or an online parts store.
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Fridge is freezing everything
Check the top of the inside of the fridge. There is usually a flap door mechanism that sometimes falls off or sticks. This regulates the temp in the fridge.
Jan 29, 2014 | Amana ABB2524DE Bottom Freezer...
I have a true double door commercial refrigerator. it stay below freezing even though I set the temperature very low. it is freezing everything.
thermostats on those things are notoriously bad. probably a bad thermostat. should have numbers 1 - 9 and usually set on 5
Aug 18, 2013 | True Refrigerators
Roper refrigerator is freezing everything even when the dial is turned off. Help, a root beer just exploded!!
First check for ice build up in the freezer, which would indicate a defrost circuit failure. Look for ice build up on the evaporator coil.
You might be best served by manually defrosting your refrigerator and seeing if the indications change.
Feb 01, 2012 | Refrigerators
Our refrigerator keeps freezing everything we put in it even though we have the dial on the warmest setting. What can I do to have it work normal. Is it a thermostat?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 29, 2011 | Haier HNSE05SS Stainless Steel
What is the best temperature for the bottom freezer and refrig?
Set both dials in the middle.
If you have a nearly full freezer, add 1 dial unit.
If you have a nearly full refrigerator, add 1 dial unit.
If your freezer is less than half full, step down 1 dial unit
Refrigerator should not be less than mid-point on dial (it gets open more often).
This is a good starting point, adjust in a month or so.
Sep 21, 2009 | GE Monogram ZICS360NRRH C... Bottom...
The refrigerator temperature is too cold. Everything is freezing.
there is a dial that regulates your temperature, this is inside the refrigirator, look for it and should say cold to coldest, put it in cold or if it has number from 1-5 just put in 3
Jul 09, 2009 | Refrigerators
Frigidaire refrigerator freezes everything with setting on lowest
hello there,
try to check your thermostat setting adjust below gradually,
you set it up to coldest point that's why it's doesn't cycle on no auto shutt off and shut on,
if still not change for 12 hours still freezing up,replace thermostat by your technician,might defective.have a nice day
don't forget to rate me,thank's a lot.
May 05, 2009 | Frigidaire FRS26H5AS Side by Side...
The refrigerator is freezing everything, even when temp is adjust
Leads me to believe the thermostat is not working. See if you can find the model number located on the bottom frame near floor behind fresh food section door and I will be able to help you better, Thanks, Sea Breeze
Mar 21, 2009 | Refrigerators
Refrigerator runs too much
if set at 1 and still freezing request that they change the thermastat it is out of calabration
May 24, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
