Question about Mitsubishi WD73727 73" HDTV
Color loss After watching the tv for a couple of hours, the screen starts to flicker with really fast images or squares or lines. Then the color gradually fades away and leaves a purple tone to every place there should be color, with the black and white areas remaining. If I shut off the set for 5 minutes, it will the work for about 15 or 20 before the same thing happens. This will all start over the next day with a 2 to 3 hour start up use. The bulb is 3 months old. Set is a 2005. Bill
  • douglasks Jul 24, 2008
    Bought brand new 73 inch mitsubishi - seems to work fine just on DirecTV channel. When I switch to DVD player - after a few minutes the screen flickers and then colors switch to pink pastel/black/white - can still see the image but its like watching an Andy Warhol flick. Switch back to TV and colors still off. Turn off the TV, rest a few minutes and then back on - colors are back to normal. Any thoughts?
  • genemans May 11, 2010
    So, which capacitors need replacing on Mitsubishi P/N 938P019010 as this is $780-$1780 part depending on where you are going to buy it new or rebuilt? Can you describe the general area or the exact capacitor that needs replacing?
    President:
  • 3,130 Answers
Your formatter or what is called the FMT board has bad capacitors on it.
Posted on May 27, 2008
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
Mitsubishi VS 45607: 1. TV starts out as B/W when first turned on. After about 30-60 min, the color is restored, although not in the full color spectrum. 2. TV flickers a lot vertically. After about an...
You have a bad video board. If you can find one used it is fairly easy to replace once you get into the TV itself. Your color guns could also be adding to this problem. I am not familiar with this television and its components so I dont know if you can replace one color gun at a time or if once one is shot then all three have to be replaced. That should be a start for you anyway.
Feb 25, 2011 | Mitsubishi VS-45607 45" Rear Projection...
Toshiba 32A35 Color TV Flickers & Scrolls w/ light colored images
My Toshiba 27" tv has the exact same problem any solutions out there or is it time to toss the tv?
May 24, 2010 | Toshiba MV19H1 Combo
After an hour of watching Tv the screen flickers and loses color, green lines come on the screen and the images become blurred/wobble. I can turn tv off for 15 mins and then it comes back fine, for another...
It could be the Digital board. It does most of the video processing before being sent to the Optical Engine. This is a expensive board and I recommend to call a professional to be sure.
Hope this helps,
Skyassoc
Jul 09, 2009 | Samsung DLP HL-P5663W 56" TV
Lines in screen
They are stuck pixels...
There are some that say sending strong images that change from to color to color can help unstick them, but I say only dissassembly and cleaning of the contacts (there should be 2 ribbon cables, one for top, one for side) that probably got dust in it. Call it in under warranty if at all possible.
Apr 19, 2009 | Sony KDL-52XBR4 LCD Monitor
Sony KP75HW40 unstable red. (not the usual problem)
I would suggest either the Focus block or the RED CRT drive board either one of those items could cause the symptom. A defective CRT could also, but a shorted CRT doesnt usually go back to being normal
Mar 16, 2009 | Sony KP-57HW40 57" Rear Projection...
Mitsubishi VS70707 Has developed subtle lines in picture
If they are faint white lines, they are called re-trace lines. They are caused when the current to the CRTs is too high. One way to check is to turn the brightness down. They should go away, but if the picture is too dark, you will need to turn down the "screen" control. This will take some handy work. If you are handy enough, take the grill off the front. Inside you will see a little black box, about 5 inches wide. there are 6 knobs on it, 2 for each color. One row is for focus (each) the other for screen (brightness). It is written on the part. The trick is to turn each of them down equally or risk having a slight tint of color. Really not hard at all, but requires the TV to be on to see. You shouldn't need to turn it but a fraction. Good luck.
Feb 16, 2009 | Mitsubishi VS-70707 70" Rear Projection...
The tv screen is moving really fast
This is your VSync. On older TVs, there is a dial you can adjust to hold the image in place. Do this only if all channels are appearing with the same vertical movement.
Nov 27, 2008 | Televison & Video
Missing Color.
the color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
Jan 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Open Questions:
See all Mitsubishi WD73727 73" HDTV Questions
Mitsubishi WD73727 73" HDTV Logo
437 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
