Question about HP Computers & Internet
Need operating instructions for HP Pavilion PC a6257c-b wireless keyboard. Specifically, what do the keys on the extreme left and right edges do?
    Sergeant:
    Champion:
  • 326 Answers
Those keys are programable keys for various functions. U should be able to download an instructiopn manual from HP.
Posted on May 23, 2008
My HP keyboard will not type /, but then the other way. (its after the 0 key. Key wit ? and + on)
probably your driver needs update or reinstall...
windows 7 OS : windows> computer> right click> manage > device manager> keyboards then update driver or manually download your keyboard model in HP sites :) goodluck
Nov 20, 2014 | New Hp Pavilion Notebook Dv7-2185Dx 2.0...
My shift key is not working
You have two Shift keys. on left side and right side of the keyboard.
you may need to replace the keyboard or use an external USB keyboard.
Aug 08, 2014 | HP Pavilion Computers & Internet
I can't find the wireless putton on my HP pavilion Entertainment PC dv8700
It should be located in the "F" keys on the upper portion of the keyboard...once you find the key that looks like the wireless symbol (a tower with parentheses around it) kind of looks like this:
((( i )))
once you find that press the "FN" key at the lower left hard side of your keyboard PLUS the the ((( i ))) key!
That should turn it on, or look on the edge front of the laptop with the lid open to the left of the keyboard, there might be a switch! Hope this helps, if not message me!
Aug 04, 2011 | Microsoft HP Pavilion DV6276US Notebook PC
What does the wireless connection key on the hp pc entertainment laptop keyboard look like
Hi!
There is a small wireless key above the keyboard(not embedded in the F keys) that shout be orange with the wireless picture displaying if it has been turned of.
Hope this helps.
Apr 17, 2011 | HP Pavilion dv7-1132nr Notebook PC
How do i switch the wireless on an hp pavilion dv7 series laptop
look for a switch or a button that has the wifi icon on it.
You may have to press a Fn key with the icon key on the keyboard
in some laptops.
Jul 10, 2010 | HP Pavilion Laptop dv7-1025nr
I have a HP pavilion laptop and cannot locate the FN plus button or the on/off switch to turn the wireless on / off.
This would be located on the front left, right below the mouse pad next to the left corner. Its usually a black switch that you could turn left for off, and right for on. when on it should show a blue light, and when off yellow...
Jan 04, 2010 | HP Pavilion dv4000 Notebook
How to replace screen on Pavilion dv7-1040us. is diferent from other hps I have replaced, cannot figure out how to remove it.
Here it is! Have fun!
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery2_bing.gif.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  4. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  5. Place the wireless LAN Minicard in a static dissipative bag.
Before you begin: Remove the battery.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
Dec 09, 2009 | HP Pavilion dv7-1240us Notebook
I need to replace my keyboard on HP Pavilion 9700, Notebook
well in order to get the repalcement call hp tech support i.e. 8004746836 and pay $298+taxes to get it replaced...if the NB is oow
Oct 07, 2009 | HP Pavilion dv9700t Notebook PC
Space bar missing on hp dv9000 laptop
hi go to this site and absolutely u will be able to change ur keyboard with new one http://www.insidemylaptop.com/remove-hard-drive-memory-wireless-card-keyboard-hp-pavilion-dv9000/
Jun 06, 2009 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
