Question about GE 26999GE1 Cordless Phone
Is there a way to check your messages without the answering machine?
I remember checking them with the phone before so that i could avoid making alot of noise with the answering machine. what do i do to listen to my messages on my handset instead of pushing the play button on the answering machine?
Go to:
http://www.retrevo.com/samples/GE-Cordless-Phone-manuals.html
Scroll down through the GE phone guides available . . . select your 26999ge1.
Posted on Jul 13, 2008
Answer machine not recording messages.
reset - there is usually a pinhole that can be pressed with a pin or take teh batteries power from the device wait 10 secs plug back in.
Apr 22, 2015 | Lands Phones
Gigaset 8825 answers phone but does not record message
Some Gigaset phones have an option to have the answering machine play an outgoing message only without taking a message. You should check your settings and make sure you don't have yours set up this way. This could also happen if the memory for the answering machine is full so that it cannot record any more messages.
Sep 01, 2014 | Siemens Gigaset 8825 Cordless Phone
How do I take my messages when I'm not home. Can't remember
Can you remember the make and model of your phone/answering machine?
Jan 10, 2013 | Lands Phones
My mother can't remember the numbers to retrieve messages on her GE Big button, model 29369GE-1
The 29369 isn't an answering machine. Please consult the the documentation for whatever answering machine *********** has on her phone line.
If you require further assistance, please feel free to repost your question, but be sure to specify the make and model of the answering machine.
Oct 24, 2012 | Big Button GE 29369GE1 Speakerphone
My aswering machine won't allow people to leave a message
There are usually two reasons for this if the machine is on. 1) The memory is full. In that case, delete some messages. 2) The unit is set to Announce Only. This may be the default if you haven't set a personal greeting.
Please add a comment with the model of your machine for additional information on how to change the incoming message options.
(Make sure that your phone/phone line are receiving calls. (Check for dial tone, try calling the number).)
For some older phones and answering systems, the Announce/Number of Rings before picking up was set by a switch on the back or the side of the base. Most newer phones let you set this in the Menu. Try under General Settings > Answering System or an Answering System menu item. (Again without knowing the model, I can't be absolutely sure of the menu and sub-menu lists.)
I hope this helps.
(There are a lot of AT&T cordless phones that work at 5.8 GHz with answering systems. New models come out regularly.)
Dec 16, 2011 | AT&T Lands Phones
I lost my manual. After a recent power outage, I also lost the message callers get when they call me and the machine answers. Without the manual, I don't remember how to reset my answering message. ...
Since You do do not give the phone model number I can only give you the link to the Uniden webpage where you can find links to all UNIDEN Cordless phones (900MHz, 2.4GHz, and 5.8GHz).
The DECT6.0 models are on another page: Click the downpointing arrow near the top of page to unfold the list of available products.
Jun 16, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
Would like to increase number of rings before answering machine comes on.
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
How to set the answer machine for a 3410 Binatone speak easey com
Here's you manual:
http://www.binatoneonline.com/manual.aspx
Click icon under download....then save..remember where it saves it. Usually when the machine will not record messages there are only a few things that can be wrong....check the Telephone Answering Machine(TAM) section.
You might need to erase all the data and/or change to the correct mode for the phone to function properly. Obviously having the manual will help! :-)
Apr 30, 2009 | Lands Phones
Bellsouth answering machine
TS stands for "Toll Saver"
It will ring 4 times if there are no new messages waiting, it will ring 2 times if there are new messages waiting.
This has two effects:
1) If you are calling home to check your messages, you can wait 2 rings. If there are new messages to check, then it answers immediately. If you make it to 3 rings, you know there are no new messages and you can hang up before you are billed for your call. This was more useful when you would use a pay phone or hotel phone to make a long distance call home. With a pay phone you would get your "quarter" back as long as there were no messages. With cell phones,it isn't as useful.
2) If you not home (which is implied by the fact that there are new messages waiting), it answers faster, so people calling you don't have to wait as long. This could also be viewed as a security risk... it tells your callers whether you are home or not.
- Ben
Mar 13, 2008 | BellSouth Digital Answering System 2006C...
Answering system question
I believe the procedure is supposed to be this:
Dial the phone and wait for the outgoing message.
During the message, enter your three digit security code. If you haven't changed it, the factory default code is 123. That should put you in charge of the answering machine functions through the keypad of the phone you are calling in from.
You may need to write up a "cheat sheet" to remember what buttons do what answering machine functions. I think the controls should work the same as the labeled functions on the handsets that came with the 28112EE2 phone system. That is, 1 replays the message, 2 is the play/stop button, 3 skips ahead, etc.
Jan 11, 2008 | GE 28112EE2 Cordless Phone
GE 26999GE1 Cordless Phone Logo
150 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
