Any results to this problem yet, bryanblum? My elliptical just did the exact same thing...
Not yet, i ended up hauling it to a local fitness store. They said it could be a motor and they had replaced one a few months ago that had the same problem.
Thanks, I've been dismantling mine all day! Looks like the little servo motor continued to turn after the cable was tight, causing something inside to strip (hence the clicking). The resistance magnets (brake pad things) were pulled tight about 1-1/2 inches away from the flywheel (too far). I loosened the cable nut and the cable. I plugged in the power and the servo motor rotated several degrees and stopped. No clicking. After re-setting the cable, resistance magnets, and reassembling the machine, everything seems to be working like normal. I didn't have to remove the servo motor (yet...) Lucky so far.
I will keep you posted. The technicians are supposed to let me know whats wrong today. I dont want to think how much a motor is going to run me...if that is what the problem is.
The technician told me it is the motor. They are ordering it from Schwinn. Cost will be about $120. Cheaper than buying a new eliptical.
