I followed the instructions in the manual, and put new batteries in + side up. Then I continued with the rest of that step, but I did not see a flashing red LED light anywhere. I do not understand what to...
A few things to try, based on my FG's operation:
- The most obvious- are your batteries good? Correct type?
If they are:
- When all is well the red LED metering lights will appear in the viewfinder window on the right side, in the range of shutter speed numbers.
- The red LED metering lights are only activated when you press the shutter release button (halfway). The lights go out after a few seconds if the shutter button is not held down. Just tap the shutter button to reactivate them.
- The shutter speed setting dial must NOT be on B (Bulb) or M90 (non-electronic Manual mode) if you want to see the red LED metering lights. The lights do not operate on these two settings because metering is irrelevant here (you'd be doing the metering, not the camera).
- If you're in P (Program mode) the lens aperture must be set all the way to the smallest setting (usually f22 or f16, depending on the lens). If not, you'll only see blinking lights at the top and bottom of the shutter speed range on the right in the viewfinder. That's a reminder to set the lens to the smallest (highest numeric) aperture.
Hope these help. The FG is a great little camera.
I have had the same problem, I have formatted my memory card and have even bought a new memory card, however the same problem occurs.
