Question about Samsung Microwave Ovens
My mictvave shut it self while running it any one has any solition
  • 525 Answers
First check to see if it tripped a house fuse. If you have power to the oven and no light or display, you may have a bad thermal fuse or even a faulty door switch. It will need serviced by an authorized service facility.
Posted on May 23, 2008
The oven door won't open. It happened when it wasn't being used. How do I get the door to open?
If it is a self cleaning oven try running it thru the clean cycle to see if the door will unlock at the end of the cycle.
Apr 24, 2017 | In Microwave Ovens
Microwave shuts off to soon?? REPAIRING/FIXING MICROWAVE OVEN FAN
I had picked up a very nice stainless steel covered microwave at a yard sale for 5 bucks. They had told me it worked fine but they neglected to tell me it only worked fine for 4 minutes and then it would shut its self down and then you had to wait 3 minutes for the reset to take effect and then you had another 4 minutes of cooking.
Let me tell you this got old in a hurry. I looked on the internet for expertise advice by stating my case in the google search bar. There were 20 different relays and fix this and fix and replace thats on there.
I decided to just take the back cover off and have a look for my self.
once I was inside i was touching this and poking that and noticed it was really dusty inside with plenty of left over spider homes so i used my computer air can spray and clean it all out.
I thought maybe it just might have been the problem as bad as it was in there so I plugged it in with the back still off and it shut down in 4 minutes just like before.
Something was wrong and I couldn't quit place it so I tried it again after the relay clicked back on. Then I saw it. The cooling fan was not turning.
I unplugged it and tried to turn it by hand after squirting some WD 40 on it and the plastic blade would turn but not the shaft the blade was attached to. So I got a pair of pliers and worked the shaft until it broke free. Squirted a little more oil on it and it became nice and smoooooth oh boy!!!
I then plugged it back in and set the timer to 5 minutes. By the way never touch anything inside one of these while it is plugged in.
The microwave approached the 4 minute mark and I stood there with my fingers crossed watching the fan run as smoooooth as can be.
Wallah!! it passed the 4 minute shut off mark and made it to the 5 minute mark until it quit because the timer ran out.
I did this again at 10 minutes and it made it all the way through without shutting down.
I now have a great working $5.00 microwave and it didn't cost me anything more but a little time and couple squirts of oil.
So if you experience the same early shut down time then now you can maybe good lucky like me and repair it your self by a flick of the fan blade.
I hope this will help you same some money. The Raz Shack
on Apr 22, 2010 | Microwave Ovens
Magic chief mcd1611w powers up then shuts self down?
It depends on how long it runs and the oven status (idle or dead?) when it shuts down.
It may be that the internal cooling fan is not running or is blocked, and that can cause overheating and thermal shutdown until it cools off.
For more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Magic Microwave Ovens
Emerson microwave model #mwg91111sl shut off during use. It did not trip home breaker. It appears dead. It has shut down temporarily 2x in the past year, but came back and operated normally. This time...
You need an ohm meter. This is probably a magnetron that is overheating. Sometimes a vent can get blocked by a curtain or something similar that gets pulled to the unit when the fan is running, or a bad or slow cooling fan can cause this or a bad magnetron. Be sure to short the high voltage capacitor before you do anything else in there. There should be a thermal fuse on or near the magnetron. Some units have a self resetting 'TCO' or thermal cut out. Some have a one time fuse. Some TCO's fail to reset after cycling a few times. These are usually a 'disc' type and are round , usually about the size (diameter) of a nickle and about 1/2" tall. Check for continuity, you should have zero ohms or resistance.
Sep 19, 2013 | Microwave Ovens
Panasonic microwave NN-T543W
The thermal fuse that protects the magnetron is defective or the magnetron is getting to hot causing it to shut down, if the fan is not running cools the magnetron it will shut off.
Mar 15, 2012 | Panasonic NNSD967S Microwave Ovens
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
When I place food in the Microwave and press the express button or any other button like popcorn it will run for approximately 5 seconds and then the display will start going dim or flicker. After that...
if you are using an extention cord pls refrain from doing so, kindly plug this to a wall outlet,
or this is an electrical problem, there is insufficient current to drive a high wattage appliance, thats why it seems the unit is resetting
or there is a problem with the control board it self
Aug 06, 2008 | Microwave Ovens
Panasonic NN S254BF
It sounds like one of the wires or serkits are loos so the electrisity is not getting to it all the way I would return it or take it apart and try to fix it your self.
Dec 29, 2007 | Panasonic NN-S254BF Microwave Oven
My microwave runs for 30 seconds and stops
It could be shutting off because of the heat sensor on the magnatron is over heating because of a bad capacitor or diode or the power transformer its self. This is a call for the service man BUT you know these days a microwave like this cost a couple of hundred bucks maybe a little more too. But it will possibly cost 150 or so if not more to fix the average microwave. If you really like it, then see if you can have it estimated BUT its not for the handy man to try to trouble shoot as theres extremly high voltage in these puppys even when they are not plugged in!! Good luck
Jun 08, 2006 | Panasonic NN-P794BF 1250 Watts Microwave...
Microwave Ovens Logo
29 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
