Question about Stanton STR8-80 Turntable
Direct Drive Issues
My Stanton str8-80 turntable is not functioning properly. The Torque on the drive is not as powerful as it used to be. I tried greasing it up a little but it didn't help much.
I have a Stanton turntable, model T52. I think that the internal fuse or the transformer has blown. How do I check to see if it is the transformer or the fuse or both? There is no power getting to the
I cannot view any more information in your initial post after
There is no power getting to the except that you think the fuse is intact. From my experience, there is no transformer driving the turntable motor since these operate directly from the power mains. Can you show us a picture? Dave
Dec 21, 2014 | Stanton T.50 Turntable
Does sony ps-lx200h have a moving magnet?
Hi David,
Stanton 90 USB Turntable Review. Here is an approach and you will find many.
The best informational sight by opinion to involve yourself is a place called Product reviews and is the next link.
Lenco Turntable Reviews Lenco Turntable Product Information .
This has everything you need and can be seen. Your Stanton is there. I like the resource for anything. To answer your direct question, yes , a moving magnet is a part of the Stanton family system. It is considered a professional series. Considering choice and the degree of use is yours. The stylus can wear out prematurely as reported. See for your self. You know best. Keep spinning. Fare . Well.
Jun 24, 2014 | Stanton T.90USB Turntable
Need a new belt
The best I can suggest is that you measure the diameter of the belt in mm and put that into google search with the words "turntable drive belt". Hopefully something should come up! I would suggest contacting Stanton, but I couldn't find the website for the company, so that might be a waste of time, but if you want to try have a go!
Feb 08, 2014 | Stanton T52 Turntable
Hi, I have no motor movement. Turned deck on, power is still intact. Pressed start button and got a few shudders of movement, but now nothing. There is no stiffness in the spindle and the platter moves...
As this is a Direct Drive turntable, it may be several problems. Yes, the motor could be bad, have power supply issues, etc. For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you.
Aug 26, 2013 | Stanton ST-150 Turntable
Stanton str8 60
The Stanton STR8-60 is a direct drive record deck, so this shouldn't happen unless the platter was damaged but after a little research I found that the Stanton's can get a faulty chip which is meant to regulate the speed and therefore can make it spin erratically.
Jun 14, 2013 | Audio Players & Recorders
At-pl120 getting power from cord, hear on/off switch clicking, opened witnessed contact move, yet no power, zip nothing? any ideas, isaw no fuse inside near power inlet thanks need ansswer asap so i can...
is this belt or direct drive. if its belt try replacing the belt if its direct drive and your hearing it turn on and the platter doesnt budge when you press start the motors blown. I hope This helps, by a Stanton next time not the expensive ones just a nice direct drive table .
May 14, 2011 | Audio Technica AT-PL120 Turntable
Hey guys I purchased the Stanton Str8-80 in 2003 and used it actively for the following 1 or 2 years. Shortly after that, I left it in a corner to collect dust and only recently, I started to use it again....
If the turntable has a belt drive, the belt probably has failed. If direct drive, the motor may have failed. Only a cheap turntable would have rim drive that failed. Your Stanton is not one of them.
Apr 26, 2017 | Stanton STR8-80 Turntable
The motors in my stanton str8 30 have not got any torque. can i fix, replace or upgrade them? any help appreciated
If it is a direct drive turntable, you will have to check the gears under the platter. If it is belt driven, you will have to replace the belt
Aug 07, 2010 | Audio Players & Recorders
Torque uneven on turntables, its a possibility it needs new motors what is your opinion
No, there is no motors on these things. They operate on a direct drive system. What this means is that there are various components/circuits which control it's drive function. If the torque is off on your turntables, more than likely one of the resistors is just old and needs to be replaced.
Not a job for a novice. Take it to a professional.... someone who knows about 1200s.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
Oct 20, 2008 | Technics SL-1210 Turntable
Stanton STR8-80 Turntable Logo
273 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
