My printer's Fuser Film Sleev Located inside Hot ROD Brackle was Burnt Out.
I had Changed the same. and now printer is Printing very fine. But rather it has a new Problem. Evrytime when it is printing. There is a Paper JAm problem.
Suppose i am printing a page (A4). It finishes printing but 1-1.5 inches of page keep jamed in uppar tray. and i have to pull it manually. And printer says there is Paper Jam Error.
1,435 people viewed this problem
This solution has been voted best by the Fixya Commnunity
I have a same problem .... somebody help us. :(
imalikiaf Well I too had the similar problem. Actually this problem occurs when someone pulls a paper stuck, from the paper tray & some small pieces of paper get trapped under the sensor (two sensors). These little pieces may not be easily visible, please look carefully. If you are able to locate, switch off power, open the blue plate at the rear by unscrewing two screws and take those pieces out from the opening. Even if little bit paper is trapped under the sensor, now reconnect the printer and switch ON the power, it will eject those pieces on its own. Fix the plate back and your printer is ready to use. Hope it works. Imendra Malik
Aug 17, 2011
No paper jump inside of printer canon LBP2900, but masage paper jump inside appear.
How to clear this problem
Every page has a black band about 5mm wide at the left-hand edge of the paper, otherwise printing is fine. Is this a...
I was printing just fine until it started making this thumping noise when it was printing. Not only is it making a lot...
two papers are tightly wound around the drum? i finally figured out how to open the top lid, to gaze at the red rod, i...
My hp laser jet 3500 is showing an error message in the dispaly window. It says "50.1 Fuser Error. Fuser is hot. Press...
1st gear just mounted with driving motor .it spiral/ bevel type brass gear want actual name and where it is available ...
