Question about RCA VR355 VHS VCR
Safe!!! my rca vcr doesnt play anything, it just shows safe on the display!!! it was working fine then just stopped one day..it kept my recordable tape wont eject it...how do i fix problemmm???
    Sergeant:
  • 291 Answers
Go inside and REPLACE e v e r y rubber band that u find in machine. Don't replace one or two, if you find one or two bad
REPLACE THEM ALL.
Posted on May 30, 2008
VCR Model Panasonic NV-J45:- Until just yesterday, it worked fine, only last night I tried to play a tape, the green auto-tracking light flashed a few times as usual, then the tape just kept stopping, no...
The problem is caused by the idler assembly which controls play, record, rewind, and fast forward. If the take up reel stops, the vcr senses a problem and will stop the tape. The only other thing it can be is the drive belt, sometimes it will stretch and fall off or break. I suggest a tv technician or somebody that knows their way around a machine.
Jan 14, 2011 | Panasonic PV-9451 VHS VCR
How do i record on the vcr
do you hve anything going into either the cable in or the rca (red white yellow)?
if you do then make sure the correct input is selected
Jan 19, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd's will not play in color, all of a sudden.
There is a specific chip that processs color for the video output, if you are using the RCA connection or Svideo (Yellow or black cable) try the threaded tv cable. If that doesnt work it is probably not worth the $ to fix.
TechieJon
Aug 29, 2009 | Emerson EWR20V4 DVD Recorder/VCR
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Symphonic sc 1304 combo vcr records double images
I would try to clean the heads. Before I do anything else. You can buy a good head cleaner at Wal-Mart! Good luck with this.
Mar 12, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
Rca rp5011a
Regarding RCA RP5011A
Turn on = Play + Menu (at the same time)
Turn off = Stop (will revert to just clock)
Selecting folders or changing options = Turn on then press menu to move through options and use the forward and backward buttons to change within options
Deleting a file within a folder = Select the folder through menu options (A or B) then exit menu (cycle through all options or press stop once while in menu) then press the forward key to cycle through files within folders (1 or 2) then press delete once to display "Del" next to file then press delete a second time to delete file.
Take batteries out to quickly reset recorder (will not lose saved files)
Jun 06, 2008 | RCA RP5011 Digital Voice Recorder
Actually, it's an MW24FP3 VCR unresponsive
After Checking Toshiba FAQ, it turns out that the record button must be turned off to do anything, including playback.
Mar 31, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
VCR says safe
Hello. Have you tried unplugging the power from the VCR for more than 24hrs? This may resolve the "safe-mode" feature going back to "default" and permit regular use after this amount of time elapses. That is kind of unusual for the stepping upon the remote to cause this?
Jan 22, 2008 | RCA VR637HF VHS VCR
RCA VR355 VHS VCR Logo
168 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
