Question about Sony Ericsson P1i
P1i how can i transfer the phone memory to memory stick
U will find the move option in ur "more" tab.
just select the things u want to move from the phone memory and select the option move towards memory card
thats it
its all done.........
Posted on Jun 01, 2008
I am having problem in down loading my music files in memorycard as it is saved in phone memory.Pls solve my problem. Regards
You can as well transfer it to your memory card by marking and moving your music to memory card. Create a folder called Music and move your music to that folder.
Best regards
Aug 08, 2010 | Sony Ericsson P1i
Tip
The P1i doesn't use SD cards, it uses Sony Memory Stick Micro (M2) cards.
If having issues with your SD card and camera.  Copy all files to your PC and reformat the card.   Then transfer any necessary files back to the SD card from your PC.  If you continue to have issues I recommend buying a new SD card.
on Jan 11, 2009 | HTC G1
Where to find my recieved files( beams received) through bluetooth on sony ericsson P1i
Dear friend:
If the transfer is completed you can find your file in the messages inbox folder. However, if it is NOT fully transfered it is located in the cashe (one of the hidden directories) of the Symbian OS. To delet or copy it, simply use MyPhoneExplorer and go to "File" management tab. there, in the below address you can find the file:
\Phone Memory\Shared\obex\
You can find it.
Hope you find this solution useful.
Gecko
Nov 13, 2009 | Sony Ericsson P1i
My sony ericsson p1i cannot send sms...sms send failed
take out your battery, sim and memory stick.. then turn it off for 5 minutes, then turn in on without inserting the memory stick. after that try sending sms again, if it delivered,then try it with memory stick. if u can send sms,then its ok..but if cant then your memory sticks got a problem.my suggestion is to format the memory stick..
Jan 30, 2009 | Sony Ericsson K618i Cellular Phone
Memoy stick pro dou and my p900
SE P900 does not support memory stick pro duo. it' s only support MEMORY STICK DUO (w/o PRO). i have the same problem too. my p900 only live with 32MB MS DUO and there are no more MS DUO in my city (even SE's service center)
if you wanna use your MS DUO PRO, then you'll need to upgade to P990i or P1i. that's much better then P900i (newer OS, more ROM, new keypad, plus WiFi) :D
Dec 24, 2008 | Sony Ericsson P900
Problem connecting phone to laptop
I haven't acutally got my P1i and laptop with me so I'll see what I can do from memory. When you put the P1i in file transfer mode it becomes a USB mass storage device and just presents the M2 memory stick in the side of the device as a drive letter in Windows Explorer. However, if in Phone mode it expects the 'mrouter' program to connect the phone to PC Suite using the DCU-60 cable as a serial line. In the system tray you have an mrouter icon which when you right click allows you to select the serial port to connect to the phone. You may need to adjust this recognise the phone. There are also some drivers required for the mrouter interface. Check device manager and make sure there are no yellow question marks in the ports section. You can also use Bluetooth to connect mrouter to the phone, this'll become clear when you look at the port settings! Hope this helps.
Dec 17, 2008 | Sony Ericsson P1i
I can't transfer theme my my laptop to my phone.what should i do?plssss help
Connect your phone with the USB cable, select File Transfer on the phone, and the transfer your files to it by going to My Computer and then opening your phone memory card.
Dec 15, 2008 | Sony Ericsson P1i
Hello my sonyericsson p1i dosent read my stick memory and says it's corrupted I restart it and tried to change the memry but doesn't work please of u can help me ... and thanks for every thing
I had the same issue. Mine was intermittant. Sometime the card was recognised, sometimes not. Formatting the stick was the only cure. Quad sphere icon -> Contral panel -> Other -> Format memory stick.
Dec 14, 2008 | Sony Ericsson P1i
Problem of installation of theme files with utz extension
hello,
the P1i is reading utz extension file you just have to transfer the theme file to your mobile via cable or bluetooth and go to your theme and you will find them there
Nov 03, 2008 | Sony Ericsson P1i
Theme installation
hello
you just have to transfer the theme file you have to your P1i and then it install by it self and you can find it in the theme menu
Aug 26, 2008 | Sony Ericsson P1i
Sony Ericsson P1i Logo
54 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
