Question about GPS
Magellan 4250 won't turn on after being turned off.
  • Anonymous Sep 21, 2008
    Same problem over here. I can only turn it on again pressing reset and power at the same time.
  • Anonymous Dec 25, 2008
    same problem ..... bought it from Best Buy. They sucked at helping me.... They said that it must have been broken by me.... I have owned it for exactly 5 days... it worked great until day before yesterday. I own 7 gps units and this is the only one with problems......
AZJudy
  • 4 Answers
SOURCE: Magellan Maestro 4250
I just called Magellan.....1-800-707-9971. I got my 4250 for Christmas 2007 and never did register it. We did that over the phone and then he gave me a repair order and an address to send the unit to them. It will be fixed under warranty.....my only cost is the UPS or FED EX shipping. He said I will have it back in 7 to 10 days. OUTSTANDING service.
Mine was stuck on the blue screen.......and the pin reset did nothing.
SO......best of luck to you all......and I highly suggest calling Magellan.
Judy in Arizona
Posted on Aug 23, 2008
SOURCE: I have a Magellan Maestro 4250
We had the same problem but it seems to have solved itself after I kept the power switch pushed in for an extended time after which the unit went through a start-up sequence. My guess is the this action started a reset procedure for the unti
Posted on May 12, 2009
toms920
SOURCE: Magellan Maestro 4250 freezing up
I just purchased a referb from TigerDirect and the only issue I discovered was a lockup when the unit goes to sleep. Try holding down the power button for 15 seconds then release it to cycle the unit. Then hold the power button down again for 5 second to start it back up. I had to do this for my bluetooth to work and not freeze up. Now I just turn it on and off manually and avoid having it go to sleep. I also downloaded the firmware update to 4.86, you can download it from Magellan's website. My unit works great so if that doesn't work contact Magellan and I'm sure they will have a solution.
Posted on May 29, 2009
  • 5 Answers
SOURCE: I HAVE MAGELLAN MAESTRO 4250 AND TOUCH SCREEN IS NOT WORKING WHAT CAN I DO THANKS
I got the touch screen from ebay, with search key word "4250 digitizer".
Posted on Aug 22, 2009
  • 7 Answers
SOURCE: Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Posted on Feb 08, 2010
Once I updated my Magellan Maestro 4250 the beginning Magellan screen comes on & the bar at the bottom advances like its loading then it stops and freezes. I've tried reseting it without success...
Try re booting, turn off like normal, then when you go to turn it on, hold power button down all the way through the start up, and 15 seconds more than release the on button, now it's rebooted, see if that helps, let me know.
Jun 11, 2011 | Magellan Maestro 4250 GPS
Magellan 4250 fails to turn on. Have tried both car and home power supplies with same result. Its as if unit battery is bad.
hi depending on how old your system is its probably just your battery that needs replacement ,though it should work while connected to power source check the power inlit make sure it is not damaged or broken goodluck
Mar 18, 2011 | Magellan Maestro 4250 GPS
I when turn on my Maestro 4250 the screen is all white and I don't see any menu.
Plug it into your computer to see if it recognizes it. Perform a software update from magellan's website. If it still has the white screen, press the reset button with a pen.
If none of that works, then your unit may be defective. Call magellan for a warranty replacement.
Jan 04, 2011 | Magellan Maestro 4250 GPS
I updated my magellan 4250 to v4.86 and now it will not work with the car charger. Screen states that USB is connected and I should follow prompts on PC screen. It work fine before the upgrade.
turn it on and hook it back up to the computer and once it has installed, use the safely remove hardware wizard to remove the 4250 from your computer, then plug it into your car again...if that fails, turn it on then try the reset on the side (little pin hole) use a paperc clip to reset it.
if you need further help, just reply to this post.
bill
Jan 20, 2010 | Magellan Maestro 4250 GPS
Our Magellan Maestro 4250, came on by itself and will not turn off.
is it plugged to AC charge when it comes on?
If not seek out the RESET hole and place a fine pin or paper clip end in and reset the unit
Jun 20, 2009 | Magellan Maestro 4250 GPS
Jun 10, 2009 | Magellan Maestro 4250 GPS
May 29, 2009 | Magellan Maestro 4250 GPS
There is a RESET button on the bottom of the unit on the left side
Nov 22, 2008 | Magellan Maestro 4040 GPS Receiver
GPS Logo
619 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
