Question about HP Color LaserJet 2600n Printer
Hp color laser Jet 2600n Printer not working on Network card
Hi our office just bought a new Hp printer but can't connect into our network card, may be faulty or dead, please help me out
  • 1 more comment
  • Gorgewest Jun 13, 2008
    Keep getting error message print spooler service not running
  • Anonymous Jun 15, 2008
    yes, have a same problem
  • Anonymous Jun 21, 2008
    how to configure net work printer
    Problem Solver:
  • 7 Answers
Check to see you your antivirus is not blocking it. Or you may want to check HP for the latest drivers.
Also check Windows update to make sure you have latest drivers ESPICALLY if you are using VISTA.
Posted on Jun 18, 2008
How to hook up wifi connection to hp color laserjet 2600n printer
Most WIFI adapters operate much like the old Jet Direct cards. They attach either through the Parallel Port or the USB Port on the printer.
Once it is plugged in and attached to the printer you will need to search for teh WIFI device on the WIFI network where you can configure it. Then it is just a matter of setting up the printer on your laptop/tablet like any other printer using the WIFI port defined on the WIFI network using the HP2600 drivers.
Oct 13, 2014 | HP Color LaserJet 2600n Printer
How to hook up wifi connection up to hp color laserjer 2600n printer
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
HP Laser Jet 4700 network card
HP LaserJet 4700 printer comes with inbuilt network card so you don't need to install another network card. If you want to but network card for your PC then go for 100/1000 Mbps network card.
Regards
Ashly
Feb 03, 2010 | HP LaserJet 4700 Printer
2600n color hp laser jet printer
Do calibration if this not help you need to buy new cartridge.
good luck.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Not able to print
Check for the connectivity if you have connected to network, Check for any client is using the printer spool , check this if not put me ......................|
thank you
Feb 22, 2008 | HP Color LaserJet 2600n Printer
Cant print in my network
I am having a similiar network problem, I setup the 2600n on my small-office network, plugging it into an 8 port switch along with a computer and IP camera....then connected the switch to the default router...this worked for a while as my router provided the printer an internal IP, but somehow the IP reset itself to an external IP,and print jobs I send now to the 2600n from my network will not print. I can't seem to access a configuration window to set a static IP address my router will recognize.
Feb 15, 2008 | HP Color LaserJet 2600n Printer
Hp colour laser jet 2600n
This printer should still be under warrantee, can you take it back?
Oct 16, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
197 people viewed this question
Seeker5211
Seeker5211
