Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Noise on mastercool
My mastercool makes a noise from the squirl cage only on low, however when i remove the panel to pinpiont the problem it goes away, when there is on obstructed air it makes no noise
  • deeprinter Mar 02, 2009
    My problem is similar except that I have to repair my squirrel cage because the hole on the motor side is elongated. Can anyone tell me how to get the shaft out. Mine is stuck in the bearings.
Had the same symptoms and found that tightening the squirrel cage set screws eliminated the noise.
Posted on Jul 01, 2008
How do you take the squirl cage off the ptac?
Most squirrel cage blowers slide out after removing a screw or two. What system you have? don
Jan 10, 2017 | Heating & Cooling
Hws18vh6 model # when in heat squirl cage rubs and is very noisy
It sounds to me like you need new bearing on your blower. Also before I did that I would check to make sure that a set screw didn't come loose allowing squirrel cage to slip to one side and rub. Hope this helps. Thank you
Nov 30, 2010 | Haier Heating & Cooling
Bought used - want to prevent rusting of water trough and other
If you can get to the whole water trough to coat it, I recommend you get some spray undercoating or a product like "Phil Swift" promotes on TV and spray it on the affected area.
Mar 29, 2017 | Mastercool 67680 Evaporative Cooler Air...
So when the fan is turned on it makes some awful noises behind the glove box...
there is squirl cage i call it mounted on fan motor is is the blower something caught in it or blades come apart
Mar 22, 2010 | 2003 Mitsubishi Montero Sport
Blower motor makig noise like its hitting
You must remove the motor to inspect for bent squirl cage (fan) for damage .your heating issue is seperate from the noise.you could have a bad thermostat check your temp gauge if its at least half way up to 200 degrees thermostat is ok then you will have to check heater core hoses for flow in and out to make sure they are hot. if all check out look at blend air doors make sure they operate.
Jan 06, 2010 | 1999 Pontiac Grand Am GT
I want to clean the squirl cage fan on my Carrier handler. It's 12 years old and never really been cleaned. What is the best cleaning procedure to maximize its efficiency.
The best way to really clean the squirrel cage is to remove the entire indoor blower motor housing assembly out of the furnace then remove the squirrel cage from the motor shaft and pressure wash the squirrel cage. Make sure you don't use to much water pressure as you might knock off any balancing weights that may be attached to the one or more of the vanes. Make sure the cage is completely dry before you re-install it back on the motor shaft.
Nov 16, 2009 | Kitchen Ranges
Whwn i turn the heat all the way up loud clicking noise if turned lower noise stops what could this be notfan
I think your talking about the heater fan? If you hear more noise as you increase the blower speed, there is something in the squirl cage or a problem with the blower motor itself. Leaves, paper or something lite on the pass side floor, it will get sucked into the recirculation duct,causing a noise.Remove the blower motor and clean out any debris, and inspect the squirl cage and turn the motor by hand to see if you hear any noise
Sep 29, 2009 | 2005 Ford Explorer
Fan on Carrier roof top ac makes loud noise on auto or high but not on low
this one is carrier AC with bad blower motor. Hope This Helps.
Sep 29, 2009 | Heating & Cooling
Water on the squiral cage side I don't know where its coming from
I don't know exactly what you mean by getting water on the dry side of the compartment. In any event, as you will see, there are very few sites that are dedicated to the maintenance and repair of evaporative coolers--you, in fact, submitted this problem of yours under the Air Conditioner section because there is no Evaporative Cooler section.
Having said this, I offer you two things: 1) a site that has a section dedicated to evaporative coolers, which took me a long time to find for my own problems:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers.htm
and 2) the general idea that if you have water where it is not supposed to be, it likely is because there is a hole---obviously caused by rust--that allowed such water to get penetrated through. See more on rust holes of coolers here:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Coolers_Cooler_Has_Holes.htm
This should help get you on your way.
Brad
Jun 08, 2009 | Mastercool 67680 Evaporative Cooler Air...
Loud rumbling noise in mastercool a/c
could be the fan is full off dust or something causing it to be out of balance
May 19, 2009 | Mastercool 67471 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
669 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
