Question about E-Machines eMachines Desktop PC
USB error? When I turn my computer on, the blue light that usually surrounds the power button starts flashing. When I finally reach my desktop, my mouse becomes unusable (it's a USB wireless mouse). Thinking that it broke down or something, I grabbed a USB wired mouse, and connected it into the same USB slot. The USB wired mouse glows, but then it will not move. I got one of the older mouses that used the y-slot (I think that's what it's called) and tried out my other USB drivers and none of them appeared to be working. Is there any way to fix this?
  • E-Machines Master
  • 3,051 Answers
Hi there
if you boot into bios and go under perephials you will see the usb devices ensure that it is enabled and save and reboot the system and try it out ok please try this and let me know how this works
regards mike
Posted on Feb 23, 2009
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Computer will not start
Press power button down for 5seconds until the computer shuts down. Remove power cable, press power button down 10s. Connect cable, try to restart.
Aug 17, 2012 | Dell Computers & Internet
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
When I push the start button on my old Compaq Presario 7000 Desktop PC the power light above the button goes on and the file access light to the left of the button goes on and both stay on. I don't hear...
Try doing a power flee.. that is..
remove the power cable from the computer and all the usb devices if connected and the then press and hold the power button for 30 seconds and then try rebooting the computer.
Another possibility is that.. computer is not able to find the boot sector on the harddisk due to which its not able to turn on completely.
Another possibility is that the device boot order of the computer might have changed too in the BIOS. To resolve it easily we need to chat with each other, so reach us at hnetworking.com
Feb 13, 2011 | Compaq Presario 7000 (470004-759) PC...
HP had blue screen and said it would shut down. Problem is that it does turn off, so that it can be re-booted. Have tried to shut off PC, but continues to come on and not start.
Hold the power button in for 10 to 15 seconds for hard shut down if that doesn't work unplug power for about 5 minutes then plug power back in and see what happens
Jan 06, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Broken USB jack, no power.
1) Unplug the computer from power. Open the computer case.
2) TOUCH the metal frame of the computer case. (Not shouting)
This will relieve your body of Static electricity.
3) Unplug the front panel USB cable from the motherboard. (If there are two cables coming from the front panel, unplug them both)
4) Close the computer case.
Press the Power On button in, and hold it in for a count of Five seconds. Let go of the button.
Do this procedure two more times. (Total of three times)
What you are doing is clearing any CMOS Error Codes, and setting BIOS Setup back to the factory default settings.
5) Plug the computer back into power. WAIT 1 minute. Turn the computer on.
If the computer still doesn't start, the motherboard is fried.
(I believe the computer will work okay)
There is no Service Manual available. If you follow the cable/s from the front panel to the motherboard, you'll see where it/they connect.
Jan 17, 2010 | Dell OptiPlex GX520 PC Desktop
Dell Dimension Computer will not turn on
Hi try taking the front face panel off first and see what is obstructing the button and put the panel back on again.If you dont know what to look for behind the panel then its better to take it to a repair shop.
Dec 24, 2008 | Dell Dimension 3000 PC Desktop
No anything
Flashing amber power button indicates a failure of the power supply.
Jun 14, 2008 | Dell Dimension 4600 PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
E-Machines eMachines Desktop PC Logo
80 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
