Question about Kenwood KAC-9102D Car Audio Amplifier
Powers up- and turns off!
I have 2 9102D Car Audio Amplifiers set up in my car with 2 Alpine type Rs...One of them powers up perfectly, but the other one is giving me a hard time! It turns on, then turns off. Any suggestions?
    Genius:
  • Kenwood Master
  • 1,550 Answers
If they go in to protection mode the audio amplifiers IC's are damaged and you gotta to change him.Good luck
Posted on Jun 02, 2008
Will it push 2 alphine type rs
no it could one 12 but no 2 and def not a 15 when mach speakers to a amp you want to mach up the rms power you want to amp to put out enough to power bolth speakers so like 2 500 watt rms you would want a 1000 watt rms amp
Apr 01, 2010 | Alpine MRP-M650 Car Audio Amplifier
Powers up no sound out
Hello jreinhard623,
Check the speakers and wiring by substituting a known good speaker and check the amp inputs and RCA cables. Also make sure that the input gain and other controls are set properly. If there's still no sound, the amp itself is probably defective.
Nov 08, 2009 | Alpine MRD-M300 Car Audio Amplifier
Only powers subwoofers when at high volume
Well, make sure that the output level on your head unit is up, and also try adjusting the gain NEVER EVER PUT IT ON FULL GAIN BECAUSE THAT WILL CLIP THE AMP AND MAY BLOW AMP AND/OR SUB!!!
Oct 08, 2009 | Alpine MRP-M1000 Car Audio Amplifier
How too hook my kac 7201 up to my two dual 4 ohm Alpine type Rs
Hello manbearpig65,
Well, that's a 2-channel amp, so it's really best used to power a set of regular speakers.
The best power solution, for your existing components, is to wire each of your subs voice coils in parallel, resulting in a 2 ohm load, and then run each sub off a separate channel from the amp.
The amp is stable only to 4 ohms in bridged mode, so you would series the sub voice coils (8 ohm load) and then parallel them (4 ohm load) to the amp bridged connection. This will result in less power to each sub than if you ran them separately.
Hope this helps.
Apr 10, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Carlos
i have a 81000d for sale for 250 dollars car money still in perfect condition i am pushing 3 12 inch alpine type r subs
Apr 25, 2008 | MTX Thunder 81000D Car Audio Amplifier
Alpine mrd-m501 amp
Disconnect the speaker wires from the amp, then try it again. If the error message doesn't appear, try connecting the speaker wires back to the amp one by one.
The error message is due to some sort of overcurrent in the amp. If the error does not go away when the speaker wires are disconnected, the issue is most likely with the amp itself and will need professional repair.
Mar 18, 2008 | Alpine MRD-M501 Car Audio Amplifier
Alpine 1507
I would either try a bigger fuse, if possible, or turn the power output dial on the back of your amp down. This can be done with jus a simple flathead screwdriver. I suggestion would be to go out and buy a power monitoring cap. Wal-mart, or Tweeter usually distributes them. It'll have a LED reading on the top, with two wire hook-ups either on the bottom or the top for positive and negative, place this in between your amp and your subs in the wiring set-up.
Feb 25, 2008 | Alpine MRV-1507 Car Audio Amplifier
No sound from speakers after mra-f350 connected to alpine w205
Did you set the digital output to the on position on the bottom of the head unit?
You have to switch the head unit off then back on for it to recognize the position of the switch.
Oct 27, 2007 | Alpine MRA-F350 Car Audio Amplifier
Powers up but no signal
Check your gain pots as well as audio pre outs on amp. sometimes pre outs will get loose and be unable to make a connection.
Jun 19, 2007 | Alpine MRD-M301 Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
105 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
