Question about Brother IntelliFAX 1270E Plain Paper Fax
I do not have a manual
I need to know how to get a conformation for each fax I send
I need to know how to put the date time and name on each fax
    Scholar:
  • 143 Answers
Ask, and ye shall receive:
http://pdf.textfiles.com/manuals/FAXMACHINES/Brother%20Intellifax%201270e%20Fax%20Machine.pdf
Please make sure you have Adobe Reader installed on your computer first: http://www.adobe.com/products/acrobat/readstep2.html
Enjoy!
Posted on May 23, 2008
Is there a way for me to leave a date/time stamp when sending a fax on my intellifax 1940CN?
if you enable send report you can get an a4 page with time and date confirming that the fax has been sent, but when set up it will print for every fax. the other option is to have it print on error only and you can manually print report of sent recieved items( all date and time stamped) with the number sent to as a list.
Aug 10, 2009 | Brother IntelliFAX 5750e Laser Fax
Date and time wrong on the journal
to reset the time and date on the machine you need to hit
Time/date
Function-7-1-start- then adjust the time and date and hit start then stop
Com journal after every fax
Function7-4-start-1-2-start-2"should says always" then start stop
receive time print." puts the time and date of your machine of the fax..example if your receiving a fax from new york and your in california it will put your time and date at the bottom.
Function7-4-start-9-start-2"should say valid" start then stop.
as for why your losing your time and date all the time is because the battery if dead on the machine.
hope this helps.
Jan 07, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Conformation after a fax
from the feeder in back? the fax system on this is not that hot, actually, but you can try to change the confirmation settings from the main panel.
no worries, check for up to date printer drivers here
Feb 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Time
This should take care of it for you.
NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
  1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
  2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
  3. Press the [Start / Enter] button.
  4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
    NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
  5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
  6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
  7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
Dec 13, 2007 | Office Equipment & Supplies
Canon fax/copier
1 Data Registation
2 Set
3 Set (when User Settings displayed..includes date, name etc.,)
4 Time & Date
5 Set etc..
Nov 15, 2007 | Office Equipment & Supplies
How to send a fax to multiple recipients
After each number you dial, press "SET" then dial the next number
After you put in your last number hit "SEND"
You will receive a confirmation with a compilation of all the numbers you sent to after all numbers receive their faxes.
Sep 05, 2007 | Canon 730i Laser Printer
Brother IntelliFAX 1270E Plain Paper Fax Logo
29 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
