Question about Vacuums
Kenmore elite quiet pak 2 there is a F and H flashing and the cycle does not continue....what does this mean and how do I fix it?
  • Layla4ever Jul 26, 2008
    My Kenmore Elite is flashing a dL and an F. The door is also locked. Please help!
    Thanks!
  • Anonymous Apr 16, 2009
    My kenmore elite quiet pak 2 will stop mid cycle and flash F 06.
Mine is having the same problem =\
Posted on Jun 23, 2008
Fix direct drive on kenmore elite vaccuum
Make there is no obstruction clogging the hose inlet btween hose and container unplug when checking and put togather prior to checking and keep hands and fingers clear when doing so.
Feb 22, 2015 | Kenmore Vacuums
Tip
Best Upright Vacuum You Can Buy!!
Paying a high price for a vacuum does not translate into best performance. My daughter purchased a Dyson (over $700.00) and after considerable goading, she accepted the challenge I had posed. Clean her carpet with her Dyson until she was satisfied that it was clean and then use my Kenmore SensorClean (no longer available by that name and over 10 years old) over the same area and see the results for herself. After the test, she stated she could feel the difference on her bare feet and immediately purchased the Kenmore Elite Bagged Upright Vacuum Cleaner ($279.00). The Dyson is now collecting dust (on the outside). With a build-in fiber-optic dirt sensor, you don't have to guess when the carpet is clean, the vacuum lets you know via the lights. Its suction power is second to none, the extra long cord lets you cover more area without having to change outlets and the direct-drive means no belts. You have 30 days on any purchase to return it, so try it for yourself, you may soon be purchasing a new vacuum that is worth every penny.
on Apr 04, 2015 | Dyson Vacuums
How do I use the attachments on the Kenmore elite upright vacuum cleaner
Unplug hose from the base ( floor vacuum part) plug in hose...... should be good to go. May depend on your model
Dec 11, 2014 | Kenmore Vacuums
Dc31 flashes green
Hi there, it's Jack at Dyson.
Usually if the indicator light flashes green when the trigger is pulled, this means the machine needs to be charged. If you have had your machine connected to the charger assembly for over 3.5 hours and continue to see the flashing green light, this could mean the machine isn't recharging correctly.
In order for us to diagnose which part is at fault we'd need to take you through some simple diagnostic checks when you have your machine to hand. You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Aug 03, 2014 | Dyson DC31 Bagless Handheld Vacuum
Every time we try and re charge batteries up in these machines (we have 2) they constantly flash red - does this mean the battery life is at its end or is the problem with the charger?
it could be either or, if you have a multimeter,, check the charger for voltage, and also check the batteries, if the batteries are too low at the start of a charging cycle it will make the unit give you the flashing red lights, But my guess would be to make sure the charger itself is still supplying the required voltage and amps needed,
Jul 04, 2011 | Vacuums
I can not get alarm to work on Constant elite colour change LCD alarm clock
Underneath clock there is 4 buttons, 2 of which are marked (m) & (s) and the other 2 buttons marked with arrows for (up) & (down). depending if you have the clock, alarm or date showing press down on the (s) button for about 3 seconds and the hour digit will start flashing, use the (up) & (down) arrows to set your hour. Then press the (s) button again just briefly and the minute digit will flash and use arrow (up) & (down) buttons to set this also. Press the (s) button again and all will stop flashing and Alarm or Time or Date will be set. Hope this helps as i had same problem but figured it all out in about 2 minutes as i couldn't find my manual lol,.
Jan 27, 2011 | Vacuums
The light on my Roomba flashes amber very quickly when plugged in directly with the adapter. what does this mean? it usually flashes slower when docked.
If Roomba senses that its battery has been significantly discharged, Roomba will enter a special 16-hour refresh charge cycle. When the 16-hour refresh charge is initiated, the CLEAN light will quickly pulse red/amber. Do not interrupt the cycle once it has begun. The 16-hour refresh charge cycle is initiated by the robot and cannot be started manually.
For long-term storage, always remove the battery from Roomba and store in a cool, dry place. Blue or black batteries should be stored after Roomba has been used. Yellow batteries should be stored after being fully charged.
Battery capacity reduces overtime and usually the battery will need to be replaced each year.
May 14, 2010 | Roomba Robotic Floor Bagless Vacuum
Hoover Deluxe Elite Rewind does not pick up
Check the hose and take the bottom plate of the vacuum off to check for obstructions that you can't see right away. Use a wire coathanger (unwound) to push any clog through. I also have dogs and this vacuum. It does get clogged with fur occaisionally.
Apr 08, 2009 | Vacuums
Vacuums Logo
344 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
