Question about Mitsubishi WS-55511 55" Rear Projection Television
Picture has a blue ghost.
My ws-55511 has been working fine, then tonight the picture has a blue ghost in it. Any ideas on what is causing this and how I can fix it?
Thanks
  • 2 more comments
  • lccaster May 23, 2008
    Our Panasonic big screen is doing the same and is also distorting the picture on the top and bottem as well.
  • Frederi May 23, 2008
    Guru, Not sure if this is how I answer your question...
    The Letters do look a bit 3D, as in they are shadowed. It looks a lot like the ghosts the old tube TV's used to get, but a bit more distorted. With lettering it looks more 3D and with people or objects it is more an outline, say around the head, shoulders, collar -- always going to the left.
    Than you for your help, I hope this explains it a bit better.
    One more comment...This morning, we now have yellow over white areas and the blue is connected to black areas. So a black shirt with white areas on it, the black has blue coming form the edges and the white appears yellow.
    Is this a lamp issue?
  • Frederi May 24, 2008
    Hi Thank you very much for getting back to me. We called a TV repair shop and that is exactly what the problem is...the blue and yellow convergence ICs are out. They took it to the shop to fix and to confirm the problem.
    I appreciate you sharing your knowledge, it was very helpful.
    Thanks!!
My t.v has been having the same problem
Posted on Aug 30, 2012
  • Mitsubishi Master
  • 8,617 Answers
Does writing and the image appear as if 3D? Let me know and I can help you out with the problem.
Posted on May 23, 2008
  • Sonny Berry
    Sonny Berry May 23, 2008
    That can only be two issues. 1. the convergence ICs need to be replaced. Or 2. the blue CRt needs the coolant changed. Is there any way you can send a pic of whta the screen looks like then I can tell you for sure.
The picture is bigger then the screen how do I adjust so that the picture is same size as TV thanks
Please confirm tv model number as question shows its Mitsubishi WS-55511 rear projection tv.
This info will help me to suggest a solution.
Do you get correct colors in picture though its over size?
Thanks.
Aug 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi 55" MODEL WS 55513 1080 HDTV blue screen
I plugged my Dell desk top in and the XP screen comes up, but when windows comes on I getablue screen. Any ideas?
SimTech@gmail.com
Jan 21, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The TV was working fine until one day the picture no longer appeared. A friend told me that he had a similar problem and he was able to easily change a bulb inside. I pulled the TV from the wall and I have...
These don't use bulbs to my knowledge,they have 3 different picture tubes in them.
I would look for what's called a pico fuse around the transformer. If they open that would cause no power,and no picture. Usually though, if this is the heavy 3 picture tube projection that I believe it is,then I would suspect the IC Chips which are video amps and have 40-60 legs on a single chip.
Nov 01, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My television only puts out a pic in 480. The 720 and 1080 are not working. Getting sound no picture
No input on a WS-55511 is capable of 720p . Inputs COMP1 and COMP2 ONLY accept 480i/480p . Input DTV accepts 480i/p and 1080i . When using Input DTV with a component connection(YPbPr) and you get a green or no picture then you will need to navigate the menus and setup input DTV for YPbPr instead of RGB.
Oct 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Yellow, blue and green ghosting of picture. Convergence mode will not allow realignment of the red and blue lines
Hi,it sounds like a light engine problem.Lcd Technology uses 3 chips blue,green and red that create the image ,when they start to fail color discoloration will occur.If it's an Dlp pay attention to sounds of buzzing,whirling and high pitch sounds because it could be your colro wheel.
Oct 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ghosting of the image
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55 in. Rear Projection Television No red colo
do you see any red at all when you co to the convergence screen? if not, then the red CRT has died and needs to be replaced.
Jan 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TV has double picture. Ghost shadow is Blue.
looks like the t-con board failing, or a lose connection to the t-con or screen ribbons off the t-con board to the screen.
tcon-y0wguvybehhtyrwlmlutw4ro-5-0.jpg its fitted to the screen back under the shield will look similar to this.
Dec 28, 2017 | Mitsubishi WS-65511 65" Rear Projection...
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
201 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
