Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV shut down
The TV was working and suddenly screen shut down, try to reconnect but there is no power coming to the TV
  • 4,234 Answers
Sony sets have internal diagnostics. Unless the ste is 100% dead, you should see the standby light blink in a pattern of count,pause,count... Please supply that count here and I can give you details about the problem.
Dan
Posted on May 23, 2008
Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
Oct 29, 2012 | Sony KDL-46NX810 46 in. 3D LCD TV
Sony KDL46V2000 TV. Screen comes on and goes off in continuous cycle
you have a leaking cap on your power supply /open up and check on just replace those caps that looks swollen
Nov 16, 2017 | Sony KDL-46V2000 46 in. LCD Television
Hi, I replace the lamp in my Somy KF-42E200A and when I power on my TV it come up for about 3 sec and the TV shut down and power light come red. Any ideas?
Dude, you have the same problem I have EXACTLY....except my tv runs for 2 minutes before shutting down.
If I solve this (when) I will be in touch.
Nov 03, 2010 | Sony KF42E200 TV
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv suddenly quit
This would be due to a bad power supply unit.. The flyback seems fine as you are seeing a screen. Replace the PSU and you will have a good tv for more years to come.
May 21, 2009 | Panasonic TH-50PX75U Plasma HDTV
Sony kv32v15, Red screen with fine horizantal lines then shuts off
I would suggest to measure the 200 volt B+ at the CRT socket. If that voltage is found to be low, disconnect the socket from the CRT and measure again. If the voltage reading returns to normal you may have a defective CTR.
Also check for open or defective diode on flyback transformer for the 200 vdc source.
I would also suggest to take all the necessary precautions since you are working in a very high voltage area.
Good Luck.
Jan 14, 2008 | Sony KV-27XBR45 27" TV
Olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
Dec 17, 2007 | Olevia LT26HVX 26 in. LCD Television
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
