Question about HP Office Equipment & Supplies
Will not pint - HP Office Equipment & Supplies
Finally...decided to turn the computer off; then turner it back on...and the printer went to work!
Elmo Curry
Posted on May 24, 2008
Need recommended Fluid specs and amounts to change oil for 1996 Toyota Tacoma 4 wheel drive front and rear axles
Hello there,
From this page https://www.worldsbestoil.ca/product-cross-reference.php?year=1996&make=TOYOTA&model=TACOMA&engine=2.7L&vin=1
Extract.......
.Engine, 2WD, with filter - 5.4 quarts [1]
Engine, 4WD, with filter - 5.3 quarts [1]
Cooling System, Initial Fill - 9 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, A340E Initial Fill - 1.7 quarts
Automatic Transmission, A340F Initial Fill - 2.2 quarts
Automatic Transmission, A43D Initial Fill - 2.6 quarts
Automatic Transmission, Total Fill
4 speed A340F - 10.4 quarts
4 speed A340E - 7.7 quarts
4 speed A43D - 6.9 quarts
Manual Transmission, - 5.3 pints
Differential, With ADRD Front - 2.6 pints
Differential, Without ADRD Front - 2.4 pints
Differential, 2WD Without LSD Rear - 6 pints
Differential, 4WD Extra Long Rear - 4.5 pints
Differential, With LSD Rear - 6.4 pints
Differential, Standard Rear - 6 pints
Transfer Case, - 2.2 pints\'
Sep 13, 2014 | 1996 Toyota Tacoma
Oildipstickreading
I haven't seen such a dip stich but as dipsticks have a full and low reading on them then it would be logical to say that the top and bottom holes will be full and low and the holes in between would represent the number of pints needed to bring the oil level back to the full mark . So lower is I pint in the sump ,next hole is 2 pints , next hole 3 pints , next hole 4 pints and top hole 5 pints.
Dec 14, 2013 | Buick LeSabre Cars & Trucks
Download cheat
93 pints is 46 quarts and 1 pint.
May 03, 2013 | ixl.com Computers & Internet
How many qt of transmission oil those a 99 volvo s80 need
parts tore can say for sure but its usually in pints..4 pints to a quart..so 16 pints is 4 qts most take 6 qts or 24 pints..just to give you an idea..put 2/3rd of it in and start the car fill to level according to the stick.
Feb 24, 2013 | 1999 Volvo S80
How much oil would i ad to a pint of gas at a 50 to1 ratio
A pint is 16 ounces, add 1/3 ounce of oil for a 48:1 mixture.
Gary
Aug 30, 2011 | Vacuums
How much transmission should fit in a 2000 isuzu?
FOR 2.2L MANUAL TRANSMISSION HOLDS 4.5 PINTS AUTOMATIC TRANSMISSION HOLDS 18.2 PINTS. FOR THE 3.2L MANUAL TRANSMISSION HOLDS 6.2 PINTS. AUTOMATIC TRANSMISSION HOLDS 18.2 PINTS.
Aug 12, 2011 | 2000 Isuzu Rodeo
What type of Dana is in the rear of the 98 4cyl wrangler
Engine, with filter..........6.1 quarts [1]
Cooling System, Initial Fill..........10.6 quarts
Automatic Transmission, 30RH Initial Fill..........4.1 quarts
Automatic Transmission, 32RH Initial Fill..........4.1 quarts
3 speed 30RH..........7 quarts
3 speed 32RH..........8.6 quarts
Manual Transmission, AX-5 2WD..........7.4 pints
Manual Transmission, AX-15 2WD..........6.8 pints
Manual Transmission, AX-15 4WD..........6.8 pints
Differential, 181 FBI Front..........2.6 pints [2]
Differential, With 194 RBI Rear..........3.6 pints
Differential, With 216 RBI Rear..........4.1 pints
Transfer Case, 242..........3 pints
Transfer Case, 247..........3.4 pints
Transfer Case, 249..........3.4 pints
Transfer Case, 231..........2.2 pints
Feb 14, 2011 | 1998 Jeep Wrangler
What is the fluid capacity of the gear oil in a 1997 nissan 5 speed 2 wd truck
CAPACITIES
Engine, 2WDwithout filter..........3.5 quarts[1]
Engine, 4WDwithout filter..........4.0 quarts[1]
Cooling System, Initial Fill..........8.5 quarts
Automatic Transmission, Total Fill..........7.4 quarts
Manual Transmission, 2WD..........4.2 pints
Manual Transmission, 4WD..........8.4 pints
Differential, 2WD Rear..........3.2 pints
Differential, 4WD Rear..........2.7 pints
Differential, Front..........2.7 pints
Transfer Case,..........4.6 pints
1. Add extra oil when replacing filter.
refill check oil level.
TORQUES
Oil Drain Plug.....22-29 ft-lbs
Transfer case
Fill Plug.....18-25 ft-lbs
Drain Plug.....18-25 ft-lbs
Manual Transmission
Oct 17, 2010 | 1997 Nissan Pickup
What;s the oil capacity for a 2002 chevy trailblazer 4.2 6 cyl?
Here are the Fluid CAPACITIES & MORE:
Engine, with filter..........4.6 quarts[1]
Cooling System, Initial Fill..........12.0 quarts
4 speed 4L60, 60E..........11.0 quarts
Manual Transmission, NV1500..........5.7 pints
Manual Transmission, NV3500..........4.2 pints
Differential, with 8.6 ring gear Rear..........4.0 pints
Differential, with 7.25 ring gear Front..........2.5 pints[2]
Differential, with 8.25 ring gear Front..........4.2 pints[2]
Differential, with 9.25 ring gear Front..........5.9 pints[2]
Differential, Front..........2.5 pints
Differential, Rear..........4.0 pints
Transfer Case,BW4472..........2.5 pints
Transfer Case,NV136/236/246..........4.0 pints
Transfer Case,NP207..........4.6 pints
Transfer Case,NP231, NP233..........2.3 pints[3]
Transfer Case,NV231/233..........2.1 pints[3]
1. After refill check oil level.
2. Do not use synthetic lubricant in axles using RTV sealant.
Synthetic lubricant will chemically atack RTV sealant.
3. Identification: check tag on case.
Apr 13, 2009 | 2002 Chevrolet TrailBlazer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
