Question about HP Computers & Internet
I just had a tech do in home replacement on one of my hard drives on my hp 8020. He did not plug the dvd burner back in so the system does not find it. Where does the power plug go on the motherboard. I need to burn 30 dvd's for my sons graduation tomorrow!
    Genius:
  • 1,027 Answers
Without knowing if it is a PATA or SATA I'll give you a best Guess.
in the lower right corner are 4 connectors...white,yellow,black,blue. These are SATA data transfer connectors. If the dvd burner has a similar connector there should be a cable from here to the burner and a power connector from the power supply to the back of the burner like F in the picture below. Either connector F and M should come from the Power Supply.
if the burner has a connector like F it is SATA, if like M then it is IDE and a flat ribbon cable would come off the IDE connector (BLUE) under the power supply 20 pin connector next to the Ram memory modules.
Posted on May 23, 2008
Compaq presario v3000 sata will not detect or format for operating system
Hard drives can go out in any model. If you have created a restore set, you can replace the hard drive with the same size or larger.
Hope this helps
Mar 26, 2012 | HP 417065-001 - HP Compaq Presario V3000...
Can we format pc by usb drive
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
if you need more help with this post a reply
hope this helps
Aug 24, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
My cd/dvd player when playing music the sound is not constant and start to play like it slow and the dvd does the same is thair a repair for this or do i need to purchase a new cd/dvd burner/player my...
Kindly check first your software of your system.. sometimes occurred due to low performance of a system (software). do one thing, if the music your playing is from the disk... try to copy all that music from the disk and paste temporary to your hard drive.. once your done coping.. try to play the music from you hard drive.... if still same operation of your complain, means that the problem was on software....
Jul 11, 2011 | HP Computers & Internet
Does disk drive plug into hard drive
no the disk drive does not plug into the hard drive. can you be more specific on what you are trying to do what kind of system laptop, desktop are you wanting to add an cd-dvd burner to your system?
Feb 18, 2011 | Acer Computers & Internet
Hp dvd1260i is not work normal pc cant RECOGNIZE dvd drive For normal working need to shut down pc and again power SUDDEN Recision power from hp dvd1260i thanks 4 Help
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
hope this helps
Dec 28, 2010 | HP DVD1260i DVDRAM Burner
DVD drive does not show up in Computer drive list
Sounds like a cable or CD hardware issue. If you are comfortable taking apart the laptop yourself, disconnect /reconnect the cable or replace the CD cable. It's hard to update the driver if the system doesn't see the drive. Or, you could replace the drive. It's really hard to know which is the problem without testing.
Jun 13, 2009 | HP 419320-001 - HP Pavilion dv4000 Series...
Unable to reinstall DVD backups after HP SYSTEM RECOVERY failed
Code "purple" means you and your computer are done. It is an unrecoverable error that means you need a new system. However, I have found a couple of postings that claim to know a fix. I can not verify these methods, I do not own a HP or other type of prefab PC (custom is the only way to go). Anyway, here are the links, good luck.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=6115
http://forums.techguy.org/windows-nt-2000-xp/469752-code-purple-configuration-error-hp.html
http://forums.techguy.org/all-other-software/644163-code-purple-advice.html
May 16, 2009 | HP Computers & Internet
Format/restore computer to factory settings
Press F11 at system startup to get to the NEC recovery menu. From there, you can restore your factory settings. However, a "destructive" recovery will wipe the hard drive, including your personal files. Best to back those up first before performing the recovery.
Hope this helps - remember to rate :)
Oct 02, 2008 | HP 419320-001 - HP Pavilion dv4000 Series...
Hp dvd lightscribe dual layer burner problem
It could be that your drive is just getting wore out.
It could be the amount of data on your hard drive. I have noticed systems do tend to operate poorly once the hard drive get's 50% or more full. This is because windows uses part of the hard drive as memory so when the hard drive is getting full it has less memory to work with and things start to slow down and even freeze.
One slight possibility could be that the power supply has become weak and is not able to deliver the necessary power to the burner as it used to. One way to test this is to remove all devices that consume power from the power supply except for the necessary ones like the hard drive, keyboard, and mouse and see if it improves any.
If you have another computer or have a friend with a computer you can try the dvd burner in you can rule out the power supply or the rest of your system, for that matter, being a problem.
Sep 16, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
