Question about Nokia 3110 Cellular Phone
Nokia 3110 I HAVE A NOKIA 3110 CLASSIC. WHEN I AM RICH IN 1 GB MEMORY WHEN MY MOBLIE PROBLEM IN RESTART SO PLS. SUGGEST ME WHAT I DO FOR THIS PROBLEM.
    Guru:
  • 458 Answers
1 GB of memory is too big for your phone. you need to delete some files for your phone to operate normally. keeping alot of data in your phone will slow down your phone and i also keep restarting it. it it advisable to use 512MB of memory
Posted on May 23, 2008
3110 Cellular Phone: i have nokia 3110 classic mobile.The phone does no...
it s due to software problem. u cant solve it manually. so pls contact your mobile dealer or service provider. before that try to do flashing
May 18, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Security code nokia 3110 classic
pls tell me the security code or how to re format my cp
Feb 05, 2009 | Nokia 3110 Cellular Phone
NOKIA 3110 CLASSIC RESTART PROBLEM
salam
restore ur mobile factory settings
apply only builtin themes of nokia
do not fill ur mobile memory and always leave space of 500 kb
delete ur notes and celender notes
do not apply heavy wallpapers
hope the answer of question
Sep 09, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 restart problem
please remove memory card from ur phone & check again
gud luck
Jul 29, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 classic Restarting Problem
the firmware needs to be reflash or upgraded on the phone so you will need to take it into a mobile service center and have that done...or you can use you nokia software and upgrade the phone on your own.
Jun 23, 2008 | Nokia 3110 Cellular Phone
hi i am imran in kota (borkheda) my mobile Nokia 3110 c is 7 time problem in restart it is very serious and ptt problem. pleas help me. ok
May 17, 2008 | Nokia 3110 Cellular Phone
Additional Memory Card
u can use d memory card upto 2 gb in 3110c..............the memory card used in 3110 classic is micro sd card ..............the 1 gb card ll cost around 400 rupees and the 2gb memory card ll be around 800 rupees.........
May 11, 2008 | Nokia 3110 Cellular Phone
Downloading songs
how can i install video clip.
Apr 14, 2008 | Cell Phones
Nokia 3110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
